-   -   drywall + P&L screws ? (http://www.diychatroom.com/f101/drywall-p-l-screws-150323/)
Fix'n it 07-15-2012 10:17 AM
1/2" drywall over P&L ceiling. i bought a box of 2" screws. by just "eyeballing" them. it looks like i will have just under 1" into the joist. will this be enough ?
joecaption 07-15-2012 10:24 AM
Not a great plan, I would have removed the plaster first so you can see where the joist are and it would lay flater.
If your going to do it your way I also would use drywall adhesive and longer screws.
Fix'n it 07-15-2012 08:11 PM
yeah, i know. but i can't take the p&l off the ceiling = no time. i have WAY TOO MUCH on my plate as it is.
i used the 2" screws, and they worked fine. i went in the attic and drilled holes on the north side of the joists. so my screws hit the joists. sides, the few times i missed a joist, i could easily tell and put one next to it.
bjbatlanta 07-26-2012 10:35 AM
1" penetration into the joist is fine. I would have used adhesive too as mentioned above....
