Drywall Overtop Of Popcorn Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-30-2010, 04:47 PM   #1
drywall overtop of popcorn ceiling
I am renovating a bathroom and want to get rid of the popcorn ceiling. The house was built in mid 80's so im not concerned with asbestos. Im wondering what would be best/easiest. remove popcorn or put up new drywall right overtop? Any thoughts anyone?
butters101 is offline   Reply With Quote
Old 12-30-2010, 06:49 PM   #2
I scraped down my popcorn ceilings
Without removing all of it
What is left is a semi-textured ceiling
Much easier to paint & doesn't collect dust
Old 12-30-2010, 08:07 PM   #3
Rewards Points: 676
A friend of mine sprayed water on her popcorn ceiling and once it soaked in, the popcorn came down in sheets.
FWIW
gma2rjc is offline   Reply With Quote
Old 12-30-2010, 08:39 PM   #4
Drywall Texture Pro in Fl
stoner529's Avatar
Rewards Points: 154
Just remove it.
Take it from a professional texture guy and popcorn removal specialist.
Look at my blog below and it will tell you what to do.
any questions, just ask me
http://howtoremovepopcorn.com
stoner529 is offline   Reply With Quote
Old 12-31-2010, 02:48 PM   #5
Handyman
Rewards Points: 512
I would also remove it...problem is...being a bathroom, it may have been painted already. That's not so easy to scrape off. Take your fingernail and see if you can scratch the popcorn off. If you can, you're all set.
I watched you're blogger stoner. I REALLY like that masking gun!! When I scrape off texture I generally keep a wide mouth pail under the drywall knife. Much neater way and I keep larger garbage can nearby to empty it into.
canadaclub is offline   Reply With Quote
Old 12-31-2010, 03:00 PM   #6
stoner529's Avatar
Rewards Points: 154
Or you could by that thing at home depot that you can attach a plastic bag to. I hear it works. for us its easier to just ball up the plastic in sections. Only when i do it does it leave little mess, when my workers do it, they don't take as much pride and consider my way retarded because i work from the front of the house to the back so i dont have to get dirty shoes everywher.
Even if that bathroom is painted, you can always knock the balls off, and odds are a bathroom with painting popcorn, may come off pretty easy due to humidity!
how to remove popcorn
Old 12-31-2010, 05:43 PM   #7
Handyman
Rewards Points: 512
Well, I am not one to strike ego here..just adding advice to the OP
Old 01-07-2011, 05:24 PM   #8
Thanks for the advice everyone! I think I will go ahead and take it off. I aleady have the whole bathroom completly gutted, so I might as well go the distance and scrape it off now. I did scratch it a bit and it should come off without too much trouble I think. Not a big bathroom so even if it is a little difficult, it wont kill me! Thanks again.
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 09:50 AM
Textured Drywall Ceiling Repair TRACKER Drywall & Plaster 7 07-26-2010 05:55 PM
Plaster ceiling and drywall desrtrat Drywall & Plaster 13 10-08-2008 07:20 AM
Drywall over existing ceiling? billybarty Carpentry 1 03-07-2008 11:05 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
