Drywall Over Vinyl Coated Sheetrock - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-23-2013, 09:48 AM   #16
Haverhill Trade 1965
Originally Posted by joecaption View Post
I use Loctite Power Grab in a big S pattern as well as on the outside border 2" in from the edges of the sheetrock and well as a few screws where the vertical seam is.
This is a method I learned from ONYX solid surface tub surrounds Joe. Apply the adhesive in 2" circles about 6" apart and around edges. This material uses 100% silicone but works with other adhesives. It will stick a 100 lb. sheet to the ceiling with just enough props to insure full contact. The instructions say to pull it back for a few seconds after the first installation, but the suction cup effect is like trying to pull an octopus off a fiberglass boat. I also did Hardie Plank panels with the pattern too. Same effect.
Duckweather is offline   Reply With Quote
Old 08-27-2013, 02:32 PM   #17
Originally Posted by chrisn View Post
I was not putting down mobile homes, I have worked in some really nice ones, like you are trying to make yours. The last one I painted, I just removed all the trim that covered the wall paper seams, skimmed them all out, sanded, cleaned, primed and painted. It would save you a lot of work re dry walling, I would think.
Chrisn, when you did this, did you remove any of the vinyl coated paper, either by cutting or by sanding off the paper?
bgjff is offline   Reply With Quote
textured vinyl over the drywall needs repainted brenda o Painting 2 02-18-2011 07:54 PM
Joint compound over vinyl sheetrock Fergus Drywall & Plaster 5 02-04-2010 11:57 AM
Painting Vinyl Coated walls WiccanOne Painting 8 02-17-2009 09:28 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
