Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-02-2012, 03:35 PM   #1
Drywall over thermopan
I am finishing my basement and we are going to be drywalling right to the floor joists. My question is whether I should remove the thermopan for the cold air returns or leave it in place. I am worried if I leave it in place you will see it after the drywall is up. Thanks for the help in advance.
TimothyDIY is offline   Reply With Quote
Old 11-21-2012, 12:08 PM   #2
Bumping up because I'm wondering the same thing. I'll probably end up removing the Thermopan because it sure seems like it would cause the ceiling to be obviously uneven.
stayinhomewith6 is offline   Reply With Quote
Old 11-21-2012, 12:17 PM   #3
I'd leave it in place and shim the joist so there was 0 contact with it when installing the rock.
It's very common to add strapping to the bottoms of the joist instead of attaching to them.
Old 11-26-2012, 12:21 AM   #4
If I'm right the thermo pan is only 1/8 thick so who is going to notice that?
Wood floor joists before I joists will vary by more than 1/8 from joist to joist and wall studs will vary more than that with crowning
masterofall is offline   Reply With Quote
Old 12-05-2012, 04:23 PM   #5
Drywall contractor
The pan material itself isn't generally a problem. If it was installed with the screws HVAC guys normally use, that might be an issue as they hang below the joist 3/16" to 1/4". I assume that's what you're worried about. I normally change out the screws with some flay head wood screws before I hang. That should solve the problem....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 10:32 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
