Drywall Over Paneling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-19-2011, 10:23 PM   #1
drywall over paneling
What thickness of drywall can be put over paneling. we plastered over the drywall groves and that is fine but some of the seams between the sheets of paneling crack even with taping. The paneling is in good condition. Do we have to take the paneling down?
tweber is offline   Reply With Quote
Old 07-22-2011, 12:59 AM   #2
you need to make sure you drywall is anchored into the framing, if the paneling is that usual flimsy stuff I am assuming. Also you should make sure your drywall joints are definitely staggered from the paneling joints.
If there are cracks then there is too much movement, indicating your boards aren't secured properly, that is my guess anyways.
chrisBC is offline   Reply With Quote
Old 07-23-2011, 11:30 PM   #3
Registered User
Rewards Points: 526
Hard to say as we don't know the thickness/type of paneling. It could effect the drying ability of the wall unit, especially if foam board is installed on the exterior forcing any diffusion or leakage to dry to the inside. I would remove it, if mine. You need to install drywall the ADA way; http://www.buildingscience.com/docum...wall-approach/
Good time to up-grade the cavity insulation: The "biggest loser" in fiberglass insulation....
Gary
Drywall ceiling above bathtub/shower larabiec Drywall & Plaster 3 06-26-2011 01:23 PM
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 10:35 PM
Cutout in drywall around sink coutertop bananey Drywall & Plaster 4 05-04-2011 04:47 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 02:30 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
