Drywall Over P&L ? - Drywall & Plaster - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-01-2012, 04:29 PM   #31
Drywall contractor
Rewards Points: 1,070
Use adhesive and nails/screws when adding a layer over plaster. 3" screws are a bit of a stretch (unless you have 2" of plaster), will be expensive, and will be a pain to use. Consider new construction. Standard is 1-1/4" screws or 1-3/8" nails. Roughly 3/4" penetration into the framing lumber. Most plaster and lath is 1" thick (nominally). If you're using 1/4" rock, 2" fasteners are fine.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 06-01-2012, 04:42 PM   #32
Drywall contractor
And I definitely wouldn't tear out any ceilings unless absolutely necessary
Old 06-02-2012, 10:06 AM   #33
Rewards Points: 236
oh, believe me. i DO NOT want to take the ceilings down. the main reason i asked about going over it is = will it cause any issues ? like mold or whatever.
Fix'n it is offline   Reply With Quote
Old 06-02-2012, 12:05 PM   #34
Drywall contractor
It's done all the time. Shouldn't be any issues.
Old 06-03-2012, 09:09 AM   #35
Rewards Points: 236
ok, thanx. i am looking for a used drywall lift on craigslist.
any tips on locating the ceiling joists ?
Old 06-03-2012, 03:43 PM   #36
Drywall contractor
I'm assuming this is a first floor where you can't get in the attic and get an idea where to start. The joists SHOULD be running the shorter direction of the room size. I take a nail (8d, 16d, whatever you have on hand) and come off of the wall (parallel to the direction the joists are BELIEVED to be running) a foot or so and start "searching". Drive the nail in. If you don't hit anything, move over about an inch or so (either direction) and try again. Keep on until you hit something solid (wood). Measure over 16" and see if you hit something solid again. If not try 24". Basically, you're going "fishing" and hopefully the joists are on some kind of pattern. You really need to find each individual joist! Sometimes in older homes, they may not necessarily be on any certain centers. Be sure when you hit wood to find both sides of the joist (keep driving your nail on both sides until you hit "air". Make mark in the center of the joist. Go to the opposite end of the room and use your measurements to find the first joist on that side. Repeat the procedure to find the centers on that side too (things could be out of square). Chalk a line from one side to other on the center of the joists and you're good to go. If it was a sheetrock ceiling you're going over, once you find a joist you can use a "keyhole" saw to jab into the board, saw until you hit wood, then move over 3/4" to figure out the center of the joist....
Old 06-04-2012, 08:03 AM   #37
Rewards Points: 236
thanx. but i can get in the attic. i am thinking i will drill holes next the the joists, from in the attic.
Old 06-04-2012, 11:13 AM   #38
Drywall contractor
That's your best bet since you have access.
Old 06-04-2012, 11:16 AM   #39
Just a DIY guy
If you drilled from the attic, next to each joist at a 45 degree angle, the exit holes should be pretty close to the center of each joist.
M3 Pete is offline   Reply With Quote
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 07:08 AM
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 09:32 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
