Drywall Over Hurricane Straps - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 08:49 PM   #1
Drywall over hurricane straps
I have quite a few of these hurricane straps to deal with. Is it best to cut out the drywall around these straps and then hot patch the hole?
scubadore is offline   Reply With Quote
Old 12-30-2011, 09:06 PM   #2
Rewards Points: 12,812
Just make sure the nails are set and go right over them.
Old 12-30-2011, 09:22 PM   #3
Even with the nails set there may be a noticeable bump. And I won't be able to screw in very close to the straps either. I was considering using glue over the metal.
Old 12-30-2011, 09:28 PM   #4
Trust me, no one but you will know or see it. Your over thinking this.
Old 12-30-2011, 10:12 PM   #5
OK, thanks Joe
Old 12-30-2011, 10:59 PM   #6
KemoSabe
loneframer's Avatar
It looks like whoever installed those was conscientious of the guy who will follow him. I agree, just rock over it. We always glue and screw.
I've worked on many homes that were loaded with straps, clips and hangers. No special considerations were ever given to hardware.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 12-30-2011, 11:37 PM   #7
Too Old
You will not notice unless they do not cut for the transition to the strap.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 12-31-2011, 05:45 AM   #8
I agree. Just put drywall over the electrical protectors which nail to the face of the stud and they're pretty close to the thickness of hurricane straps. No problems. I think all of us DIY guys really over think it!
JustADoc is offline   Reply With Quote
Old 12-31-2011, 03:49 PM   #9
Registered User
Rewards Points: 4,912
Just a side thought;I would air seal the plywood/stud joints while it is open. Caulk the cathedral ceiling drywall where it meets the wall top plate (before wall drywall) to stop heat loss (ice dams) there if in a heating climate. Did you pass frame inspection?
Gary
Old 12-31-2011, 10:11 PM   #10
retired union carpenter
Send a message via Yahoo to coupe
we always hung right over them. glue and screw/nail, if and ran diagonally- corner braces? run bead of glue on entire strap to prevent rattles. nobody will ever see them unless you tell or point them out!
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 01-01-2012, 11:54 PM   #11
Thanks everyone. This is an older home, the room was never finished. The framing passed back in 96.
Old 01-02-2012, 12:05 AM   #12
Registered User
Good to know, thanks!
Forgot the references for you;pp. 21; http://www.engr.psu.edu/phrc/trainin...ngbarriers.pdf
http://www.buildingscience.com/docum...d-135-ice-dams
http://www.buildingscience.com/docum...wall-approach/
Gary
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 06:49 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
