Drywall Over Existing Ceiling? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-15-2009, 10:51 AM   #1
Drywall over existing ceiling?
Just wondering - is it normal/acceptable to just drywall over an existing ceiling instead of taking it out and attaching the drywall to the joists?
Any thoughts would be appreciated!
Curious_16 is offline   Reply With Quote
Old 04-15-2009, 11:05 AM   #2
How large is the ceiling?
What material is the "old" ceiling?
redline is offline   Reply With Quote
Old 04-15-2009, 12:09 PM   #3
Rewards Points: 1,910
If insulation is above the ceiling it can be a lot less messy to just layer it as you described. If the existing drywall is not level you can attach/level furring strips through it to the ceiling joists and attach the new drywall to the furring strips.
Old 04-15-2009, 02:18 PM   #4
I'm not exactly sure how big, its several rooms - probably 1500 sq ft or so. And I'm not sure what it is now. Its not tiles, its all one "piece", but needs to be replaced (or I guess covered) because the prior owner had lots of strange light fixtures and other wiring coming through the ceiling.
I just wondered because it appears that is what our contractor is doing and I wondered why...
Thanks!!
Old 04-15-2009, 03:54 PM   #5
If it's on the 2nd floor it will give you a little added insulation
If on the 1st floor it will cut down on noise between floors
Old 04-15-2009, 04:42 PM   #6
SNC
I would not say it is normal, but there really isnt a problem with it. Better fire protection. And as mentioned sound. As long as the fasteners are long enough.
SNC is offline   Reply With Quote
Old 04-15-2009, 04:49 PM   #7
I think its normal when the attic has blown-in insulation
And in old houses there is a lot of dust & junk above the drywall
Former owner here added 3/8" drywall on top of the old 3/4" wall in one room
Old 04-15-2009, 06:38 PM   #8
Drywall contractor
Rewards Points: 1,070
A lot less mess from tear out and less cost (less labor if no tear out) by going over what's there. It's quite common and acceptable....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Ceiling drywall thickness shtoink Drywall & Plaster 11 01-01-2009 07:05 PM
Drywall vs. drop ceiling for basement DIY4EVER Building & Construction 23 11-15-2008 07:24 AM
Ceiling joists spans drywall in a basement? Indianer Drywall & Plaster 14 06-09-2008 02:51 PM
Hanging Drywall over ceiling tiles bjorgens Remodeling 4 12-19-2007 12:59 PM
