-   -   Drywall over existing ceiling? (http://www.diychatroom.com/f101/drywall-over-existing-ceiling-42495/)
Curious_16 04-15-2009 11:51 AM
Just wondering - is it normal/acceptable to just drywall over an existing ceiling instead of taking it out and attaching the drywall to the joists?
Any thoughts would be appreciated!
redline 04-15-2009 12:05 PM
How large is the ceiling?
What material is the "old" ceiling?
jogr 04-15-2009 01:09 PM
If insulation is above the ceiling it can be a lot less messy to just layer it as you described. If the existing drywall is not level you can attach/level furring strips through it to the ceiling joists and attach the new drywall to the furring strips.
Curious_16 04-15-2009 03:18 PM
I'm not exactly sure how big, its several rooms - probably 1500 sq ft or so. And I'm not sure what it is now. Its not tiles, its all one "piece", but needs to be replaced (or I guess covered) because the prior owner had lots of strange light fixtures and other wiring coming through the ceiling.
I just wondered because it appears that is what our contractor is doing and I wondered why...
Thanks!!
Scuba_Dave 04-15-2009 04:54 PM
If it's on the 2nd floor it will give you a little added insulation
If on the 1st floor it will cut down on noise between floors
SNC 04-15-2009 05:42 PM
I would not say it is normal, but there really isnt a problem with it. Better fire protection. And as mentioned sound. As long as the fasteners are long enough.
Scuba_Dave 04-15-2009 05:49 PM
I think its normal when the attic has blown-in insulation
And in old houses there is a lot of dust & junk above the drywall
Former owner here added 3/8" drywall on top of the old 3/4" wall in one room :(
bjbatlanta 04-15-2009 07:38 PM
A lot less mess from tear out and less cost (less labor if no tear out) by going over what's there. It's quite common and acceptable....
