Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 02-01-2011, 06:32 AM   #1
Drywall over Drywall
I'm remodeling my kitchen which was previously has terrible wallpaper that has been glued and is very difficult to remove & I really don't want to gut the whole kitchen to save time a potentially create more work for myself considering going over existing drywall with 1/4 for a new finished look
Alcarte is offline   Reply With Quote
Old 02-01-2011, 06:37 AM   #2
Stay-at-home GC
Glue and screw. Stagger you joints. Use 2.25" screws
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 02-01-2011, 07:12 AM   #3
That sounds like a plan, thanks a million
Old 02-01-2011, 07:32 PM   #4
Definatly glue it, PL 400 or something like that but use 3/8 drywall as 1/4 is just for bending
masterofall is offline   Reply With Quote
Old 02-02-2011, 04:23 PM   #5
Drywall contractor
1/4" drywall is fine for laminating over existing drywall. It is used for radius walls, but NOT exclusively for that purpose. You definitely want to glue between the layers. The big box stores sell drywall adhesive suitable for the purpose, but only in the quart tubes, so you'd have to invest in a larger "caulk" gun. As stated above, one of the "PL" family or even Liquid Nails in the regular tube will work. Gypsum industry specifications for fasteners in wood framing indicate that "nails must be of sufficient length to penetrate through the wallboard and into the wood framing no less than 7/8 inches and screws must be of sufficient length to penetrate at least 5/8 inches into the wood framing, having passed through the wallboard". That said, 1-5/8" drywall screws are more than adequate. If you prefer to nail (as I do on wood framing), 1-7/8" phosphate coated drywall nails are available at a drywall supply yard, but they likely don't sell in the small boxes (I buy 35# box at a time). And 1/4" drywall is available in 12' lengths at most drywall supply yards if you want to lay the board down rather than stand up to minimize joints.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 10:02 AM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
