Drywall Over Cement 'blocks' ? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-03-2011, 07:49 PM   #1
Question
drywall over cement 'blocks' ?
I began my bathroom renovation today in a 1920 brownstone in brooklyn.
I will be tiling the tub/shower area, the rest will be drywall with wainscoting. I have a question on putting up drywall over the concrete blocks that were supporting the tile I removed.
Can I screw the drywall directly to the blocks using concrete screws?
I was thinking to use some liquid nail as well.
I took some pics so you can see what the blocks look like.
Excuse the mess I'll be removing the garbage tomorrow...
I've renovated 4 baths in the past, this is the first time I've dealt with this
kind of wall. There are a few sections where the blocks fell off with the tiles.
The rest of the block is in good shape and is not going anywhere unless I put a hammer drill to it. I think saving the block and using it as a level surface to put the drywall on is the easiest thing to do, but if I'm wrong please let me know.
this is a close up of the wall construction, some of the wall came
off with the tile in this section.
thanks for looking,
- Jonathan
jthn is offline   Reply With Quote
Old 01-03-2011, 08:02 PM   #2
Rewards Points: 558
I would use cement board/backer board and screw it to the blocks as manufacture suggests tape all seams with the special tape required and water proof all seams.
epson is offline   Reply With Quote
Old 01-03-2011, 08:15 PM   #3
thanks,
I was going to use durock in the tub area to give the tiles a smooth surface to sit on.
The rest of the bath will be painted so I wanted the smooth surface of drywall to work with.
Can you skim coat cement board to look like plaster?
Old 01-03-2011, 08:29 PM   #4
Rewards Points: 558
yes you can...
Drywall over Drywall.. NoviceHandyman Drywall & Plaster 6 01-10-2011 08:32 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 02:30 PM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 04:34 PM
Applying texture on smooth cement interior walls Flt_Simulation Remodeling 8 05-14-2009 05:23 PM
Drywall down to cement Jettech Drywall & Plaster 1 03-07-2009 12:10 PM
