Drywall Over Ceiling Tile - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-06-2010, 06:01 AM   #1
Drywall over ceiling tile
I would like to know if one can install drywall directly over sealing tile or do we have to install a layer of vapour barrier
Albert Fex is offline   Reply With Quote
Old 12-06-2010, 06:58 AM   #2
DIY staff
Rewards Points: 7,174
Removing the ceiling tiles before installing the drywall is the best way-----
However, if you choose to overlay the tiles(which is a bad plan) no vapor barrier will be needed.
Old 12-06-2010, 07:21 AM   #3
the Musigician
DangerMouse's Avatar
Personally, I would not do this.
But if you do..... 5/8" drywall (required for ceiling) + 1/2" of ceiling tile = 3" screws.
DM
Old 12-15-2010, 11:05 AM   #4
Drywall contractor
Rewards Points: 1,070
!/2" is ok for 16" centers. If the new USG "ultra-light" 1/2" drywall is available in your area (HD is carrying it around here), it is ok for 24" centers according to the manufacturer. !/2" of tile + 1/2" of drywall + 1-5/8" screws. We use 1-5/8" screws on 2 layers of 5/8" firecode for fire walls. I'd still tear out the tile if it were mine to make sure the framing will support the extra weight. I'm assuming you're going over the old 12"x12" "staple-up" tiles. They're normally attached to 1"x4" strapping that often isn't well fastened to the 2"x framing because the tile is light weight....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Removing Tile / Reusing Drywall daviswhite Drywall & Plaster 4 03-23-2010 11:36 AM
drywall for vaulted ceiling mdudu Roofing/Siding 5 03-02-2010 12:24 AM
Replacing drywall without removing tile through an interior wall MLP Drywall & Plaster 6 08-06-2009 11:35 AM
wet attic insulation and ceiling drywall rojas66 Drywall & Plaster 4 03-04-2009 03:33 PM
Using drywall for Drop Ceiling rickkeeter Drywall & Plaster 8 02-13-2009 07:52 AM
