Drywall Over Cedar Shakes? Can I Do It? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-22-2009, 10:19 PM   #1
drywall over cedar shakes? Can I do it?
I have a 3 season porch that I have recently sealed up with new windows and a new solid wood door. Whoever built it put the same cedar shakes that were on the outside of the house in this room. As I am trying to make it into a 4 season porch I want to put drywall up. Can I just drywall over the shakes instead of removing them? Any help is much appreciated.
thanks,
PC
newowner is offline   Reply With Quote
Old 04-22-2009, 10:51 PM   #2
"yeah...we do that!!!"
sounds like you don't want to do the tear out...
how are you going to put trim on the windows or finish off the sheetrock around the window openings, you'll have to add some trim to make it all better
there is nothing wrong with going over the old shakes. good insulation too!!!
good luck
KOHNSTRUCTION is offline   Reply With Quote
Old 04-22-2009, 10:54 PM   #3
hey i'm new at this DIY thing i tried to answer you but i'm not sure if you got it.
just letting you know that there is nothing wrong with doing that it will just be interesting to see how you're going to trim out round the windows
Old 04-23-2009, 09:43 AM   #4
thx. I think what I'm going to do is put a scrap piece of drywall up near a window and then see....#1 if it will go over the shakes....and #2 what will have to be done for the window trim.
Old 04-23-2009, 02:54 PM   #5
Registered User
Termite's Avatar
Do yourself a major favor and lose the shakes. Drywalling over the shakes is poor practice to say the least, and it will not make a good solid installation at all.
Old 04-23-2009, 04:12 PM   #6
Drywall contractor
Rewards Points: 1,070
Tear the cedar off and fasten directly to the studs....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-23-2009, 05:28 PM   #7
Rewards Points: 490
The wall with the cedar shakes on it was probably the exterior wall of the house with an open porch attached when the house was built. Along the way, someone enclosed the porch to make it into another room.
A lot of people enclosed the front/back porches on their homes once tv and air conditioners came along.
gma2rjc is online now   Reply With Quote
Using Felt with Cedar Shakes freddmc Roofing/Siding 32 10-08-2011 11:26 AM
tearing off cedar shakes ponch37300 Roofing/Siding 8 07-01-2008 01:17 PM
cedar shakes: nails vs staples.... MichaelinOmaha Roofing/Siding 5 10-12-2006 05:22 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
