Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 09-12-2011, 06:23 PM   #1
Drywall over 4" block wall base
There's an 8' wall in my mother's den that has a course of concrete block as a base. It's 4" block and the wall is framed up directly on top of this single course of block. Thus, the bottom 8" of the wall is block and the remainder of the wall is framed out with wood.
What's the best way to go about securing drywall to the block portion of this wall? Should I just glue the bottom 8" of the drywall?
The block is filled and has three coats of DryLok over it on both sides. No immediate concerns with water infiltration - should I use mold resistant drywall regardless?
JustADoc is offline   Reply With Quote
Old 09-12-2011, 06:25 PM   #2
Tileguy
Bud Cline's Avatar
Pl-400.
Old 09-12-2011, 06:27 PM   #3
Originally Posted by Bud Cline View Post
Pl-400.
Quick reply, thank you! I'd also like to avoid damaging the seal with the DryLok if possible and would like to avoid screwing anything into the block. Would PL-400 be reasonable to use in attaching baseboard molding to the drywall face? Any considerations there before doing so?
Old 09-12-2011, 06:30 PM   #4
Tileguy
Bud Cline's Avatar
Yes, but you may have to also use a shorter pin (nail) at a steep angle into the drywall to help follow any and ins and outs. If the surface is flat no problem as long as the base isn't warped.
Old 09-12-2011, 06:31 PM   #5
Excellent! Thanks, Bud!
Old 09-12-2011, 06:33 PM   #6
Tileguy
Bud Cline's Avatar
Good Luck!
Old 09-12-2011, 07:51 PM   #7
Moderator
kwikfishron's Avatar
So JAD are you going to update us on your other threads with your solutions?
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 09-12-2011, 11:47 PM   #8
Yup, just have to find time to get over there and take some photos of what has been done so far. Trying to research for the next step in the process (electrical + drywall). Most of the work is inside now.
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 07:23 PM
Building partition wall behind base cabinets bluefitness Building & Construction 3 11-09-2010 07:49 PM
Crinkles on full wall drywall seams. Big issue? bteudt Drywall & Plaster 9 06-30-2010 05:16 PM
Removing built in drywall shelves to wall mount TV homerb Project Showcase 0 05-19-2010 01:34 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
