Drywall On Oak Doors - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-06-2013, 06:46 PM   #1
Rewards Points: 12
drywall on oak doors
I`m going to replace old drywall as I remoldel(1950`s house).The house had new oak interior doors put up a few years ago.How do I keep all the dust and mud off the nice doors?Would plastic saran wrap work?I`ve already removed the trim around doors going to replace it.
ndmick is offline   Reply With Quote
Old 01-06-2013, 06:48 PM   #2
Framing Contractor
Rewards Points: 78
The doors can be easily removed from the hinges to prevent any damage during construction.. With a proper finish on the jambs, the dust can be easily removed later.
sixeightten is online now   Reply With Quote
Old 01-06-2013, 06:58 PM   #3
Rewards Points: 12
The doors and jams are urethaned nice thick.I will remove doors at pins in hinges.
Old 01-06-2013, 07:58 PM   #4
Rewards Points: 12,804
Or just lay a piece of 6 mil. plastic over the door and use blue tape.
By leaving the door on all the dust will not be blowing into the rest of the house.
Old 01-06-2013, 08:29 PM   #5
Framing Contractor
Rewards Points: 78
That would keep them from getting dinged though. Draping a painters tarp or a blanket over the opening works well to control dust. If access is not needed, then plastic and tape to seal the entire opening.
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
Removing built in drywall shelves to wall mount TV homerb Project Showcase 0 05-19-2010 01:34 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
