Drywall In New Build - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-11-2013, 05:01 PM   #1
Drywall in new build
I wanted to get some thoughts on the drywall being hung in my new home. To me it seems poor, but I have very limited knowledge. Please offer your thoughts. I'd like to avoid problems and address it now if I need to. If you think it's bad, what can I do... contact the super and then higher up if needed?
Drywall in new build-img_20130511_085914.jpg   Drywall in new build-img_20130511_083532.jpg   Drywall in new build-img_20130511_085019.jpg   Drywall in new build-img_20130511_085854.jpg
WebD is offline   Reply With Quote
Old 05-11-2013, 05:36 PM   #2
I wouldn't worry about it. They'll use tape/mud and you won't see any cracks. Around the windows, part of it will be covered by the trim. Same for the doors.
diycoder is offline   Reply With Quote
Old 05-11-2013, 06:33 PM   #3
Rewards Points: 89
I would worry about it...that is terrible.
REXAMUS is offline   Reply With Quote
The Following 3 Users Say Thank You to REXAMUS For This Useful Post:
Nailbags (05-12-2013), user1007 (05-11-2013), WebD (05-12-2013)
Old 05-11-2013, 06:52 PM   #4
Rewards Points: 12,858
That is one crappy job.
Looks like you have ceilings taller then 8' and instead of ordering wider sheetrock like a pro would do they just patched it in.
Looks like they cut the sheets on the back side instead of the face side and just ripped them off.
Looks like they used an ax to cut out around that gas line.
Not a great plan to have a seam over a window like that.
Some of those outside corners look like they used a chain saw to trim them.
Looks like a first time DIY job to me.
WebD (05-12-2013)
Old 05-11-2013, 07:00 PM   #5
Rewards Points: 528
You are correct Joe, but if they have a good finisher, no problem. After all they can fix most any mistakes.
framer52 is offline   Reply With Quote
The Following 2 Users Say Thank You to framer52 For This Useful Post:
oh'mike (05-11-2013), WebD (05-12-2013)
Old 05-11-2013, 07:18 PM   #6
Thanks for the input guys. I plan to address it with the builder. I'll at least have it documented. I was disappointed when I saw it today. I don't know a lot, but it just looks like crap to me. It's from larger builder with a good reputation, but it looks like crap to me.
The builder has also failed to insulate a portion of an exterior wall too. The interior has... like an arch built floating over the interior side of the wall and they said they can't really put insulation behind it and it won't be a problem (they should have insulated the wall before putting the arch in which blocks their access).? I live in Phoenix and can't understand the idea of leaving a section of an exterior wall without insulation... The section is about 9 ft tall and 20in wide.
There was also a small section (2in x 2in), above the wall, lower portion of the rafters, with a small gap because they didn't cut a piece of wood to fill the V shape of a rafter. I could see right through the area. The builder just sprayed some orange foam to "seal" the spot and then closed it in with drywall... that bothers me too. It seems like that could affect shifting and the foam will break down/not insulate like a piece of wood.?
Old 05-11-2013, 07:29 PM   #7
In your first, second and third picture where there's short end walls they should have nailed it on the outsides not the middle in my opion so there would be less screws or nail heads to finish. The outside metal trim would have covered them up.
There is no excuse I can think of for not insulating the whole outside wall, but no one here was there to see why it was not done.
WebD (05-12-2013)
Old 05-11-2013, 08:09 PM   #8
Rewards Points: 89
My first drywall job was bad but that makes me look like a pro. Yea, the finish is what REALLY matters but that's just ugly.
The Following User Says Thank You to REXAMUS For This Useful Post:
WebD (05-12-2013)
Old 05-11-2013, 08:46 PM   #9
Framing Contractor
Rewards Points: 98
Just awful
Why so many nails? No glue? Why not glue/screw?
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
WebD (05-12-2013)
Old 05-11-2013, 08:48 PM   #10
It's ugly alright. I don't understand why so many of the sheets appear broken too and how that affects them. It can't be good. I get that the finished product can still look good, but would think the broken boards, etc. would affect settling.
Old 05-11-2013, 09:01 PM   #11
Here are a few more pics.
Drywall in new build-img_20130511_084222.jpg   Drywall in new build-img_20130511_083959.jpg   Drywall in new build-img_20130511_084409.jpg
Old 05-11-2013, 09:24 PM   #12
kwikfishron's Avatar
Rewards Points: 90
That's pretty bad. Do you have pictures of the rest of the build up to this point? You don't need to post them in "this" thread, just asking.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
WebD (05-12-2013)
Old 05-11-2013, 09:42 PM   #13
Too Short? Cut it Again!
Terrible job. It is going to take a lot of mud in places. And that one piece where the drywall is broken as you look at on edge? And the piece with the pipe coming out of it that is fractured?
This was clearly done by someone other than a drywall contractor---I hope.
The Following User Says Thank You to user1007 For This Useful Post:
WebD (05-12-2013)
Old 05-11-2013, 09:47 PM   #14
Renovating My Land Yacht
Rewards Points: 616
Just wow, even if the finisher is a master there are going to be issues later on down the road. This is a shoddy job. Definitely get with the builder on this and let them know this is unacceptable. There is no way no matter how good the finish is on some of these areas that you are not going to have issues down the road.
forcedreno2012 is offline   Reply With Quote
The Following User Says Thank You to forcedreno2012 For This Useful Post:
WebD (05-12-2013)
Old 05-11-2013, 09:48 PM   #15
Rewards Points: 89
I hope the rest of the build is in better shape. That's far from professional.
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
