Drywall Near Bottom Of Shower Pan - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-02-2013, 09:19 AM   #1
Trucon01's Avatar
Rewards Points: 510
Drywall near bottom of shower pan
Hi All,
I'm at the point to add more Durock and have a small issue. If you notice, I'll be putting a piece of board along the top flange of the pan. This would leave an "r" looking space for drywall. Once the drywall in installed, I plan on putting cornerbead then mudding.
The end result should be bullnose tile along the corner of the entire wall, which would overlap onto the drywall.
Am I on the right track or should I be doing something else here?
Thanks as always everyone!!
Jeff
Drywall near bottom of shower pan-photo-1-.jpg   Drywall near bottom of shower pan-photo-2.jpg
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 04-02-2013, 09:41 AM   #2
since you'll most likely be installing a shower door why not just use drywall in the dry area? Are you doing a membrane over the CBU or poly under it?
bova80 is offline   Reply With Quote
Old 04-02-2013, 09:54 AM   #3
Trucon01's Avatar
Rewards Points: 510
I will be putting Redgard overtop of the cement board. Havn't decided about a shower door vs shower curtain...
Old 04-02-2013, 10:23 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 850
Do a door if you can swing it Jeff.
Also, if you tile and grouting is good, the drywall should be fine as it won't be regular moisture.
Old 04-02-2013, 10:38 AM   #5
Trucon01's Avatar
Rewards Points: 510
So if I do a door, it looks like I should add another 2x4 for backing, correct?
Old 04-02-2013, 10:52 AM   #6
Rewards Points: 12,802
Door or curtin it's always best to add something to attach it to.
I just use a 2 X 6 laying flat so there's no way to miss it.
Old 04-02-2013, 11:06 AM   #7
Trucon01's Avatar
Rewards Points: 510
Yea, I'll throw in another 2x4 on both sides, just in case... So I'm OK with adding more MR drywall to the outside area that tile will cover up?
2 more questions...
1. The gap where Durock meets drywall, should I use drywall compound to cover the gap or the mesh and thinset I use for the cement board? or nothing?
2. Can I cover the drywall in this area with redgard? This drywall will be covered by tile.
Old 04-02-2013, 11:29 AM   #8
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
When I did my shower I cut the CBU to fit and include that little "R" shape all the way to the outside corner. I wouldn't put drywall down there. While it may not get direct shower spray, it will get wet. Especially if you use a curtain.
The Following 2 Users Say Thank You to Blondesense For This Useful Post:
oh'mike (04-07-2013), Sir MixAlot (04-07-2013)
Old 04-02-2013, 11:43 AM   #9
Trucon01's Avatar
Rewards Points: 510
If I put cement board all the way to the edge, I would then have to tile the edge of the other wall to cover the end of the cement board.
I added drywall so I could put on corner bead and mud that other wall to make it look nice, considering the shower wall will have tile to the edge.
Make sense?
Old 04-07-2013, 07:00 PM   #10
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 848
I agree with Blondesense.
I'd also use vinyl cornerbead in that area aswell.
Sir MixAlot is offline   Reply With Quote
Old 04-07-2013, 07:47 PM   #11
DIY staff
Rewards Points: 7,174
If you can do it---use Durrock in that lower area----escaping water ruins that spot on a lot of tubs and showers----Blonsense is spot on----
Use your red guard on any drywall that will be cover by tile-----pack the drywall /Dorrock seam with thinset before you red guard the walls.
bottom of tub & shower flexes darsunt Plumbing 6 04-27-2012 04:07 PM
Drywall hung from the bottom up benjamincall Drywall & Plaster 4 08-06-2011 10:14 PM
Drywall Around Mixing Valve in Shower DaveTile Drywall & Plaster 4 04-18-2011 10:11 PM
2 Drywall boards behind shower tiles? Confused1 Drywall & Plaster 15 02-15-2010 10:06 AM
Drywall or Denshield behind Shower Walls? atilla137 Plumbing 3 07-20-2008 10:11 AM
