Drywall, Nails Or Screws? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-22-2009, 12:46 PM   #1
Drywall, nails or screws?
I'm replacing the drywall in my house. Should I specify whether I want the drywall to be nailed or screwed?
Any opinions as to which is better?
bmancanfly is offline   Reply With Quote
Old 07-22-2009, 01:37 PM   #2
Rewards Points: 502
Screws. Nails always seem to have a tendency to work their way loose.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 07-22-2009, 01:43 PM   #3
General Contractor
Anything specific you want done should always be specified in the contract. I prefer screws and glue but to each their own. If you use nails you have to glue the ceiling. Also make sure it is double nailed (nails spaced 2" from each other).
ARI001 is offline   Reply With Quote
Old 07-22-2009, 03:26 PM   #4
RippySkippy's Avatar
Around here they use both...nails to hold it in place... then it's screwed off. Some use glue others don't. The BI determine minimum nail spacing with no credit (fewer fasteners) for glue.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 07-22-2009, 06:11 PM   #5
General Contractor
I wasn't referring to the edge or field placement of nails. When you nail drywall you are supposed to place a nail 2" from the previous nail to reduce nail pops and increase holding power. Spacing guidelines for fasteners can be found in Table R702.3.5 of the IRC.
Old 07-23-2009, 08:15 AM   #6
Originally Posted by ARI001 View Post
I wasn't referring to the edge or field placement of nails. ...
That's fine, know the code well...I wasn't insinuating anything...just sharing what's common in our area. Our BI are quick to point out that the DW fastening schedule doesn't change with the application of glue in addition to nails/screws.
On the topic of gluing drywall...I had a house that was built in '73. One day I leaned against a wall in the kitchen, and you could feel the drywall give about a 1/2" or so. When I remodeled, I could see when they installed the DW, in field, there was one nail at the top, middle, and bottom in addition to glue. The glue held fine...BUT the paper had let go of the drywall. Not a believer...just an unnecessary step.
LMASD
Old 07-23-2009, 09:06 AM   #7
General Contractor
I didn't think you where insinuating anything. I just thought you misunderstood what I meant about 2". Wow, three fasteners that's just bad glue or no glue!
Old 07-23-2009, 09:33 AM   #8
Just one of the many, many joyful surprises at that house...man am I glad it's outta my life!
LMASD
Old 07-23-2009, 10:15 AM   #9
Rewards Points: 3,130
Didn't think anybody used drywall nails any more. Our local big box store doesn't even carry them.
What's the trick to get drywall screws all the way in? cody21 Drywall & Plaster 14 08-09-2009 11:05 PM
New Drywall Installation, 1 joint screws are popping zjowens Drywall & Plaster 29 01-02-2009 12:26 AM
Drywall - Nails or Screws? digthisbigcrux General DIY Discussions 6 03-20-2007 04:31 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 07:51 PM
