Drywall Nail Types - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-29-2011, 04:04 PM   #16
Drywall contractor
Rewards Points: 1,070
It's called "Industry Standard". I've had to do repairs on drywall that is applied with adhesive and it is definitely harder to remove. Still no excuse NOT to use adhesive. Don't know your actual experience "in the field" dealing with "nail pops", but quite often in new construction (especially houses built in wet, cold, winter months), what you refer to as "a few nail pops" can literally be hundreds throughout a house. Touching up all of those areas and repainting, can lead to quite a bill for the general contractor who, as a rule, has to warrant such things for a year. Lumber "shrinkage is the main cause of nail pops. Even though I will go back an do the touch up at no cost, I assure you the painter will not repaint for free. It doesn't take much of my time to fix the "pops", but the repaint can be quite costly....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 07-29-2011, 04:14 PM   #17
AGWhitehouse's Avatar
Been in the field for 12 years on lots of projects now with dozens of GCs and dozens of architects. Never once heard or seen of glueing gyp to studs, but if that's your bag, all the power to you....
speaking of bills, I would imagine the cost of all that glue and the time to install it accounts for a good portion of the painting nail pop fixes, since, as you said, you repair them for free...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 07-29-2011, 04:14 PM   #18
the Musigician
DangerMouse's Avatar
I don't want to offend anyone, but I did my whole house (new framing AND drywall) with no adhesive (and screws) by myself, and I have not had one 'pop' anywhere. I also mudded and painted by myself.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
AGWhitehouse (07-31-2011)
Old 07-29-2011, 05:08 PM   #19
Rewards Points: 150
BJBAtlanta, I'm aware that building methods are different all across the nation. Even in San Antonio you can give a set of plans to 10 different builders, all will be built different, and all will be correct- I'm aware of that. But I gotta ask, what kind of lumber are ya'll having to work with that shrinks? Everything here is kiln dried to 19% moisture meaning there is no shrinkage of the lumber. It might grow a hair from absorbing some moisture but shrinkage-no. I've fixed thousands of nail pops over the years from others work and usually I find the nail is not set properly leaving the drywall loose causing the pop. Every one I've ever done if I put a screw on each side of the pop, the nail is no longer in contact with the drywall and requires setting.
In regards to adhesive use with drywall. Sounds like a few of you have never been asked to install a sound proof drywall. You CAN NOT use any metal fastener at all as it transmits the sound vibrations thru the wall. It's strictly a glue process and you have to know what yer doing or it'll bite ya. I'd bet our bud in Atlanta has seen this.
TrapperL is offline   Reply With Quote
Old 07-29-2011, 06:43 PM   #20
DIY staff
Rewards Points: 7,174
Originally Posted by AGWhitehouse View Post
Glue sheetrock? WOW... I can't imagine the curse words people must use that have to renovate the panels you've hung. Seems very excessive to save yourself from a few nail pops...
I'm surprised that you are surprised---DW glue is pretty common.
Old 07-29-2011, 07:04 PM   #21
Rewards Points: 256
Originally Posted by kevsprojects View Post
I know I know - its all about the screw thing , but I'm faster with a good weighted hammer and a pouch full of nails. I cant really explain that but I think its related to a back operation I had 4 years ago. The pushing force of the screw gun really torques my back, yet I can swing the hammer with ease!
Guess I'm one of the ancient nailers!
you might be using a bad screw gun. some older screw guns are a bear to engage the clutch . also you only need regular 1-1/4 bugles corse thread prevered with 5/8th or 1/2 inch . nailing in the field i would not reccomend for a begginer anyways . you need to double the nails and its alot easier to dmage the paper. you could use a few nails to hold the sheet up though on the upper perimeter.
oldrivers is offline   Reply With Quote
Old 07-29-2011, 09:35 PM   #22
Your right about the bad screw gun. I acquired it (and many more tools) from my father-in-law who passed away a few years ago. I think it had been put through the ringer! I remember him hanging allot of drywall in years back. I have watched videos of guys pre-tacking with nails. That could be helpful!
kevsprojects is offline   Reply With Quote
Old 07-30-2011, 10:20 AM   #23
Drywall contractor
Lumber i kiln dried here too, but not always dry throughout the framing process. It may sit on the lumber yard and the job site in the rain for days on end , depending on the time of year. Framing may be done when it's rainy and the house may not get dried in right away. Lumber can absorb a lot of moisture. It's not every house, but a lot of them, especialyy in the winter time in this area that can be affected. Once the heat i turned on, everything starts drying out.
As for cost, using glue doesn't take any more time. While one guy is cutting the sheet, the other is gluing the studs or joists. Average house will take perhaps $120.00 for glue.
And TrapperL is correct. the drywall still has to be pushed tight to the framing member for either a screw or nail to hold properly. Not doing so will cause pops for sure even with glue...
Old 07-31-2011, 08:34 PM   #24
Surprised for sure. I'm surprised it's condsidered standard practice. Renovating a space where all gwb was glued seems a nightmare, especially when the reason is a couple of nail pops. But in America, the land of "built to last 20 years and then bulldoze it for a new building", it all seems reasonable.
Drywall nail types kevsprojects Carpentry 4 07-27-2011 10:42 AM
Drywall ceiling above bathtub/shower larabiec Drywall & Plaster 3 06-26-2011 02:23 PM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 05:34 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Nail Gun Plastic Nail Casing frustrations smark General DIY Discussions 6 07-07-2008 09:10 PM
