Drywall Mystery... Solved? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 06:47 PM   #1
Drywall mystery... solved?
So I posted another post and got a lot of answers about my home.
One big question no one was sure of was... what was this?
I decided to do some holes to find out. I started with the side. Removed some drywall, only to be stopped by wood. I drilled a hole there, only to find the wood frame to extend quite far. I then decided to make a hole on the top.
Here is what is inside that hole...
No idea what that green stuff is for...
I looked into that hole and saw some cuts in the framing and old drywall. This was built in after the wall was put up.
I then noticed ** AROUND ** the box
Here is my theory:
A different home owner / hobbyist wanted a new outlet. They cut framing and drywall to fish wire. They then built this box to either restore structural integrity or because they were unsure of how to repair the hole.
Odd theory, I know, and I would love to hear any more!!
James
daxamite is offline   Reply With Quote
Old 02-23-2012, 06:54 PM   #2
Rewards Points: 81
I duuno, that is so weird. Its probably a box someone built so that later on someone would take the time to investigate only to be yet more baffled! Hopefully, an expert can come along and say what it really might be. Unfortunately, we may never know!
Mike
shelzmike is offline   Reply With Quote
Old 02-23-2012, 07:00 PM   #3
Rewards Points: 13,694
And what do you plan to do now. It's looks horrible and would be a simple fix.
Old 02-23-2012, 07:02 PM   #4
Rewards Points: 340
Here's my theory -
They installed the over sized door, removed a heater duct or damaged some carpeting and it was easier to build a box than repair the carpet ?
(or trying to restore structural integrity after removing the framing and header to make the door wider ?
tribe_fan is offline   Reply With Quote
Old 02-23-2012, 07:39 PM   #5
Rewards Points: 81
Or, even though it seems too far away and probably should have been on the top...but could it have been some kinda of auto door opener that was attached to a larger door?
Old 02-23-2012, 08:39 PM   #6
Rewards Points: 512
its for little ppl so they can look out the peep hole in the door lol
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
boman47k (02-25-2012)
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 07:08 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 05:49 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
