Drywall Mud On Old Painted Block Wall? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-14-2010, 01:41 PM   #1
Drywall mud on old painted block wall?
I am repainting my grandsons room and took down the paneling that was on the walls. the block wall under has a good coat of paint but looks like crap.
I want to know if i can smooth out the wall with drywall plaster OR Westpac Redline wall texture?
Which is best to use or can I use either? (plaster is cheaper but i do have enough redline to do both walls if need be)
Will either fall off later?
Will the grout seams cause eitherr to fall out later since its a 1/8" think layer of plaster to fill them in?
Will mositure from outside be a issue (though the wall is 50+ years old and painted both sides,
Will I ever play the piano again? (sorry couldnt resist the soap opera-ish questioning)
Never done this and wondering if I should even try with either.
Wife doesnt want drywall so i have to plaster or leave it untouched (ick) and paint.
Thanks in advance.
urborn2die is offline   Reply With Quote
Old 09-17-2010, 07:43 PM   #2
Rewards Points: 256
you can try that but no guaruntees , i would fur and then rock over ... this will also let you put some insulation while your at it.
oldrivers is offline   Reply With Quote
Old 09-17-2010, 08:54 PM   #3
Rewards Points: 502
pretty sure mud needs something with a little bite to stick to.
you could probably do it like they do stucco, then just smooth it, but I'll give another vote for sticks and sheets
forresth is offline   Reply With Quote
drywall over cinder block smitty1960 Drywall & Plaster 6 11-14-2010 08:47 AM
Drywall or plaster wall cprao Drywall & Plaster 1 02-03-2010 03:53 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Insulate Top of Cinder block wall HooKooDooKu Building & Construction 0 01-20-2010 10:58 PM
Can you glue drywall to painted conrete block pillars? yummy mummy Building & Construction 30 03-11-2008 08:26 PM
