-   -   Drywall mud on old painted block wall? (http://www.diychatroom.com/f101/drywall-mud-old-painted-block-wall-81421/)
urborn2die 09-14-2010 01:41 PM
I am repainting my grandsons room and took down the paneling that was on the walls. the block wall under has a good coat of paint but looks like crap.
I want to know if i can smooth out the wall with drywall plaster OR Westpac Redline wall texture?
Which is best to use or can I use either? (plaster is cheaper but i do have enough redline to do both walls if need be)
Will either fall off later?
Will the grout seams cause eitherr to fall out later since its a 1/8" think layer of plaster to fill them in?
Will mositure from outside be a issue (though the wall is 50+ years old and painted both sides,
Will I ever play the piano again? :whistling2:(sorry couldnt resist the soap opera-ish questioning)
Never done this and wondering if I should even try with either.
Wife doesnt want drywall :censored: so i have to plaster or leave it untouched (ick) and paint.
Thanks in advance.
oldrivers 09-17-2010 07:43 PM
you can try that but no guaruntees , i would fur and then rock over ... this will also let you put some insulation while your at it.
forresth 09-17-2010 08:54 PM
pretty sure mud needs something with a little bite to stick to.
you could probably do it like they do stucco, then just smooth it, but I'll give another vote for sticks and sheets
