Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-24-2009, 05:50 AM   #1
Is drywall mud considered combustible?
I've run into a situation where my friend wants to frame a non-combustible arch above his woodstove that is too close for clearances. I'm thinking metal studs and concrete backer board. My question is if the drywall mud is considered combustible or not? I would also need to use find out if a plastic corner bead would be okay or if there are any other options. Thanks in advance.
the carpenter is offline   Reply With Quote
Old 01-24-2009, 07:31 AM   #2
the Musigician
DangerMouse's Avatar
mud is not combustible, i'd avoid using plastic
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 01-24-2009, 08:07 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Example: Compound is used on seams of fire-rated sheetrock, on fire-seperation walls, for code compliance.
- Build Well -
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
