Drywall Mud 2nd, 3rd Coats - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 04:57 PM   #1
Drywall mud 2nd, 3rd coats
After the first coat of mud do I use the same mud (premixed) and thin it out? On the last coat do I use finishing mud?
Tboy is offline   Reply With Quote
Old 11-20-2011, 10:23 PM   #2
A Little Of Everything
Rewards Points: 1,364
The green lid mud is used for taping & primary mudding. Blue lid mud can be used for final coat(s), but doesn't have to be.
DrHicks is offline   Reply With Quote
The Following User Says Thank You to DrHicks For This Useful Post:
Tboy (11-22-2011)
Old 11-21-2011, 09:08 PM   #3
Rewards Points: 172
I just did my first major drywall job in my basement. I used the purple lid the whole way through. I can't imagine that the other "types" of compound would make that much of a difference. I'd say use the same, like I did, so you don't end up with 2 or 3 different types of "leftovers" in the end. Just 1 partial bucket.
nateshirk is offline   Reply With Quote
The Following User Says Thank You to nateshirk For This Useful Post:
Tboy (11-22-2011)
Old 11-22-2011, 09:17 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
If you are going use just one, use "all purpose". The lid color usually depends on the brand. Do not set tape with anything marked strictly for topping and finishing. USG/Sheetrock brand mud with the green lid is an all purpose and is the old stand by for a lot of guys. Purple lid is a mid-weight and Blue lid is a light-weight. LaFarge has a couple more colors. Proform's colors are not all the same. Read the label, not just the lid color.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
Tboy (11-22-2011)
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 01:08 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 02:30 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
Drywall taping and skim coats helpless handyman Painting 7 08-11-2006 09:09 PM
