Drywall Missing Paper Backer - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By stick\shift
  • 1 Post By Sir MixAlot
Old 09-13-2016, 10:36 AM   #1
Rewards Points: 2
Rehabbing a small bathroom and the former owners glued on kitchen countertop laminate as the "backsplash"...
Obviously pulled a lot of paper off in the process.
What is the standard method to repair? Primer paint to seal, then mud? Or will mud work only, then paint. Worried about the mud being wet and then peeling off later?
What is SOP?...
MHolladay is offline   Reply With Quote
Old 09-13-2016, 10:37 AM   #2
Rewards Points: 2
Re: Drywall Missing Paper Backer
Old 09-13-2016, 10:58 AM   #3
Rewards Points: 348
Remove all of the loose paper, prime any exposed gypsum with Zinsser Gardz (oil based primer is OK if you cannot find Gardz), skim coat with joint compound, prime and then paint.
MHolladay and jeffmattero76 like this.
stick\shift is offline   Reply With Quote
Old 09-13-2016, 05:49 PM   #4
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 846
Yes do this @MHolladay !
MHolladay likes this.
Sir MixAlot is offline   Reply With Quote
Tiling bath tub surround- regard? Tar paper? Green drywall? Wonder Board? crayola110 Tiling, ceramics, marble 13 05-11-2015 08:22 PM
Joining 1/2" backer board to 3/4" drywall prestoham Kitchen & Bath Remodeling 2 02-01-2012 11:31 PM
where tile backer meets drywall rtoni Building & Construction 11 01-07-2011 10:05 AM
sanding into paper on drywall patch joseph2293 Drywall & Plaster 11 02-23-2010 09:53 PM
Taping drywall - overlap paper tape or not? newbpainter Drywall & Plaster 4 05-17-2009 11:10 PM
