Drywall Lift For Walls - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-12-2013, 07:27 PM   #1
bryanp22's Avatar
Rewards Points: 290
Drywall lift for walls
I have to do some drywall on my walls myself. Are lifts only for ceilings or can the be used for walls as well?
bryanp22 is offline   Reply With Quote
Old 09-12-2013, 07:36 PM   #2
Rewards Points: 212
We are DIY and have used a lift for ceilings and walls. It was a blessing for 5/8" on ceilings.
Here's a video that may help
orange is offline   Reply With Quote
Old 09-12-2013, 07:56 PM   #3
DIY staff
Rewards Points: 7,174
In a pinch you can use a ceiling lift for walls----very time consuming---you might be better off driving some nails in to act as props and muscle the board up onto the nails--then shift the board up and quickly screw it off.
Old 09-12-2013, 09:09 PM   #4
Renovating My Land Yacht
Rewards Points: 616
Brian,
I had to do the same while the hubby was not around. For full sheets I actually used the lift but with a ledger. I put the ledger up on the wall and then used the lift to get the sheet up and onto the ledger. The ledger I used was only a foot and a half long as we were using 8 foot sheets. I used a piece of scrap 1x3 and just kept reusing it. Took all of 20 seconds to put it up and take down and I was able to get 2 rooms done in an afternoon with it. For smaller sheets that I was able to lift myself I just used the ledger method.
Helps that we were using the lightweight stuff. Not sure I could have managed the regular stuff.
Robyn
forcedreno2012 is offline   Reply With Quote
The Following User Says Thank You to forcedreno2012 For This Useful Post:
oh'mike (09-13-2013)
Old 09-13-2013, 08:29 AM   #5
Rewards Points: 4,796
+1 with the ledger board. I used to hang drywall by myself in a pinch with a ledger board and no drywall lift. It helps to pre-hammer the screws into the drywall at several appropriate spots to make driving them with 1 hand easier.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 10:35 PM
Cutout in drywall around sink coutertop bananey Drywall & Plaster 4 05-04-2011 04:47 PM
PROHOISTS drywall lift 44070dart Drywall & Plaster 4 02-11-2010 12:42 PM
drywall lift itin1200 Tools 5 02-07-2010 01:47 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
