Is Drywall "knockdown" Still Stylish - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-06-2010, 10:21 AM   #16
Originally Posted by Big Bob View Post
Orange Peel ....sprayed on texture
Knockdown..is sprayed on then worked by hand with (wide knife)
Oh ok, I see the difference now.
I thought that smooth walls with nice glossy white crown molding and knockdown on the ceiling was more upscale and not cookie cutter at all. But then again, I haven't been in a lot of newer cookie cutters...not since popcorn era
imanerd is offline   Reply With Quote
Old 04-06-2010, 10:31 AM   #17
Knockdown replaced (Problematic popcorn) by builders (cheaper to produce than a good smooth ceiling). Then it became the "in-thing".
Big Bob is offline   Reply With Quote
Old 04-06-2010, 12:35 PM   #18
Military Mom of 4
Snav's Avatar
Any texture could be in style - depends on how well you pull a room's overall theme together with your work and chosen colors. . . the accent things such as trim and your paint/tile color really sell a texture for 'nice and planned' or 'last minute coverup.' It also depends on where you are. You can do one thing that's in style - but trash your stylish efforts by using the wrong carpet or dated tile.
In Arkansas knockdown is rare to find - people will likely find panel and white-wash smooth here.
However, to me white-wash smooth is cheap looking - found in any apartment or rental home. And, well, I'm in year 5 of removing all panel from my house room by room and replacing with drywall with heavy texture - so that tells how 'junky' I consider that to be.
In Fremont, Ca where some of my family lives the knock-down or other related textures are in style and found everywhere even in our Grandmom's house which is "high end." . . . So I consider it to be quite in style, just not very (or is very) prevalent depending on where you're located and what market you're in.
If you really want to fit in with the upswing in style times you can look at various houses that are for sale in your area and see what imrovements and changes people have made. What's 'in' in one area might be 'old' in another - or so new in yet another area that most people haven't even seen it (like heavy-texture is in Arkansas)
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
The Following User Says Thank You to Snav For This Useful Post:
Big Bob (04-06-2010)
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
