Drywall Knives - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-29-2013, 01:03 PM   #1
Jack of all Trades
lifestooshort81's Avatar
Rewards Points: 77
Drywall knives
Hi folks,
I apologize in advance for what I feel is a silly question but here goes.
What is the difference in the types of drywall blades. I've seen blades called "taping knives", blades called "joint knives". Taping knives seem to be more squared off where joint knives seem to have a rounded side.
I've always used a 4 inch 'joint knife' for taping and larger 'taping knives' for applying top coats and floating. I know how to use the tools just never really learned what the difference between them was!
Thanks!
lifestooshort81 is offline   Reply With Quote
Old 08-29-2013, 03:12 PM   #2
Rewards Points: 5,974
Joint knifes usually don't go larger than 6" and are used to bed the drywall tape in the drywall joint. Taping knives are usually 8" up and are used to bury the drywall tape and feather out the mud.
Old 08-29-2013, 06:47 PM   #3
Rewards Points: 4,780
Some of it is actually personal preference. Some taping knives (and trowels can be used as well) are actually slightly curved. Some are more flexible than others. These things come into play because depending on what you're doing you might want the flex or the curve. For example, when putting on the thick, second coat of drywall, you're trying to feather out the joint and flatten it. If you use too flexible a knife, it's going to go concave, and you'll get a depression where you actually want buildup. Same goes for the curved knife the wrong way. Using it the other way helps you apply some pressure without getting concave, or applying less pressure and actually getting a bit convex.
jeffnc is offline   Reply With Quote
Old 08-29-2013, 09:34 PM   #4
Jack of all Trades
Rewards Points: 77
OK very good... I figured it was just a preference thing but was curious as to if maybe I had been taught some convoluted way. I mean my tape seams have always come out well so I guess I've been doing something right. ha-ha!
Thanks!!!
Old 08-29-2013, 09:50 PM   #5
Go to all wall.com and type in joint knifes then tape kites and you can see the diff.
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 10:32 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
