Drywall Keeps Bubbling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-15-2012, 11:42 AM   #1
drywall keeps bubbling
Why drywall keeps bubbling
twoin is offline   Reply With Quote
Old 11-15-2012, 11:46 AM   #2
why does my drywall keeps bubbling on the ceiling
Old 11-15-2012, 11:50 AM   #3
Trucon01's Avatar
Rewards Points: 510
Post a picture. Wall, ceiling drywall?? Near window, inside bathroom? Need more information on the location of the drywall.
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 11-15-2012, 03:52 PM   #4
retired union carpenter
Send a message via Yahoo to coupe
not much information. is it the drywall paper bubbling? or the mud? if you're sanding between coats? you must wipe all dust off! it will draw into the fresh mud and pull away from dry coat. causing air to form= bubbles. if its the paper bubbling? could be faulty drywall=not enough glue when rolled. I once had an entire house 240 12' sheets faulty, when painted the paper bubbled all over once wet with paint. ended up putting two layers over whole house.
good luck
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 11-15-2012, 05:40 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 128
why does my dog wag her tail?
chrisn is online now   Reply With Quote
Old 11-15-2012, 10:53 PM   #6
because she can
Old 11-15-2012, 10:58 PM   #7
ltd
Rewards Points: 536
how does a dana posi unit work ? it just does
ltd is offline   Reply With Quote
Old 12-05-2012, 05:07 PM   #8
Drywall contractor
Rewards Points: 1,070
How long is a rope....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
