Drywall Joints That Crack - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-25-2012, 01:59 PM   #1
drywall joints that crack
My garage is four years old and the builder put in a rough drywall on the ceiling and walls (I.e. the taped the joints). I removed the tape and used the fiberglass mesh tape and then mudded and sanded the surfaces smooth. Problem is that the joints always crack?? I have been using the powdered compound and mixing it myself. Is there something that may be better (like a reinforced compound or something)?? The garage is not heated and I live in Michigan.
wgmcdonald is offline   Reply With Quote
Old 08-25-2012, 03:07 PM   #2
Rewards Points: 13,300
Why did you remove the tape?
Could be not enough screws used, someone's trying to store things on top of joist that are to long or not wide enough, compound was put on to thick, it was so hot up there the mud dryed to fast.
Old 08-27-2012, 01:58 AM   #3
Registered User
Rewards Points: 5,244
Unheated, the wood is exposed to the climate changes resulting in movement. Paper tape is better at holding/hiding stress cracks; http://www.usg.com/rc/technical-arti...ems-en-PM5.pdf
http://www.usg.com/rc/data-submittal...ata-MH1178.pdf
Keep in mind, some areas require paper tape to fire-code the drywall- if abutting the house, check locally with your AHJ.
Gary
Old 08-27-2012, 09:36 AM   #4
Drywall Texture Pro in Fl
stoner529's Avatar
Rewards Points: 154
Mesh tape cracks easier with regular joint compound. it should only be used with quickset mud.
how to remove popcorn
stoner529 is offline   Reply With Quote
Reoccuring drywall crack loehrm Drywall & Plaster 2 03-17-2011 08:28 PM
reoccuring drywall crack by window mmhendrie Drywall & Plaster 7 07-26-2010 03:47 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
finishing drywall joints Yoyizit Drywall & Plaster 12 07-22-2009 08:09 PM
Recurring drywall crack? kcrossley2 Drywall & Plaster 2 11-18-2008 10:03 AM
