Drywall Issues - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-21-2010, 06:00 PM   #1
LBr
Drywall issues
I removed some fake tile board from bathroom walls. The boards were put on over top of wallpaper with liquid nail and when I pulled the boards off it removed both the wallpaper and the first layer of paper on the drywall. Can I put a skim coat on what is left? Or what is the best way to fix this mess? I want to paint the walls.
LBr is offline   Reply With Quote
Old 09-22-2010, 05:28 PM   #2
your only choice may be to skim the walls if you are dealing with a lot of trim, etc...it depends on the damage also, to get a new look 1/4" drywall over the existing walls would be ideal but you may not be able to if you have trim and other issues to work around.
newfie49 is offline   Reply With Quote
drywall for vaulted ceiling mdudu Roofing/Siding 5 03-02-2010 01:24 AM
Attach Drywall through plywood HooKooDooKu Drywall & Plaster 2 01-20-2010 11:05 PM
Framing for Drywall Ceiling Wino Building & Construction 1 01-13-2010 03:05 PM
drywall seam issues onemeek Drywall & Plaster 16 04-06-2009 05:39 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
