Drywall Issues - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 06:48 PM   #1
Question
Drywall Issues
Hello there...
Hopefully someone may have some great ideas or solutions... 1 contractor and 4 drywall companies he has engaged later... ...and some problems still are not solved. Of course, the major ones.....
The first involves the kitchen ceiling. See attached photos.. This is after last drywall attempt to fix... The ceiling used to be textured... will never be again, so that is not an option. When they scraped it, they hacked away at it, thus the beginning of the issue in my opinion. I am not sure if that is just the primer, or the finished painted version as the paint job at this point.
The next involves a wavy wall. I have a feeling when they hung the drywall they did something..as I have the issue on both sides of the wall..but there are humps down the wall, in addition to to s-wome bad bumps. Its freshly painted. See attached photos. This wall was skim coated a couple of weeks ago. Just made it worse, it seems. One of the drywallers before him, just kept going over the bad spots making them more pronounced which definitely didn't help.
Everything that is done, doesn't help. Last drywaller said he could and would fix those issues... and didn't. Of course, I imagine he can be called back. However, I think it's going to be up to me to find the solution.
So if you have an idea, please share.
Thanks!
Drywall Issues-livroomwall112011b.jpg   Drywall Issues-livroomwall112011c.jpg   Drywall Issues-ceiling112011b.jpg
steelgoddess is offline   Reply With Quote
Old 11-20-2011, 08:13 PM   #2
You have to actually use a drywall finisher that is good and will fix I the first time around Maybe the 5th will be a charm. Check with a drywall distributed to see who they would recommend or let someone on here know where you live and you might get a recommendation.
Jmdesign is offline   Reply With Quote
Old 11-20-2011, 08:27 PM   #3
Never thought of a distributor...
I am not doing the hiring here..I have a GC....
Last one really did seem like he knew what he was doing... well rated etc.. Spent 3 days doing it... I was so hopeful.
In fact I should post the drywall version of that wall....
The last one didnt do the very heavy patches...
Old 01-01-2012, 12:24 PM   #4
continuing
I did call the distributor, and they did recommend someone. He was one of two people who came out, both seemed very knowledgable-- reinforcing to me what a bad job it is.
I am probably looking at a good week of work, needing to vacate while its done. Both mentioned loose boards-- so I started thinking back to the hanging--as the issues most likely started there. Luckily or not, as they are not the best of pics, I found some during the hanging/finishing phase. I was actually shooting other things, and happened to catch the drywall.
Its 1/2" drywall, and I see where they used 1-1/4" screws, although I believe they used a combo of nails and screws--and no adhesive. It's my understanding that for framing 16" oc that screws would have to be 16" center to center.. If someone has a correction please let me know--as I have tried to interpret the codes as best as I can. I am posting some of the pics-as to me, it doesn't seem to have that amount of fasteners..again I could be looking at it wrong. Also in the living room wall pic, the center cut out, was where the issues with that wall seemed to have began. I am not sure why they would have spliced like that on a long wall--but it appears they did.
So if anyone more knowledgable has any wisdom they can impart on the pics..i would appreciate it.
Thanks! and Happy 2012!
Drywall Issues-bedroomz.jpg   Drywall Issues-hallbathz.jpg   Drywall Issues-hallway.jpg   Drywall Issues-livingroom.jpg   Drywall Issues-livingroomwall.jpg
Old 01-01-2012, 02:48 PM   #5
Rewards Points: 13,450
Hard to see with just pictures and not being a ble to be there. The one big thing I see is that bathroom. That's got to be all done over, the sheetrock was suppost to be installed over that lip and be about 1/4 from the part sticking out where caulking would end up going once it's primed and painted.
Old 01-01-2012, 03:37 PM   #6
Thank you very much for the response.
I was wondering about that as I went through the pics..
Unfortunately, I am left to backwards trouble shoot--as that blue board bath now looks like the attached pic. So I am guessing they filled it with mud or something. I have another bath--see attached, a really bad pic-- but it looks like it would be the same. Now why one is green board and one is blue board, I am not quite sure.
Thanks again...
Old 01-01-2012, 03:54 PM   #7
firehawkmph's Avatar
Rewards Points: 1,864
Joe,
In our area the way pictured is a common practice. Gap is filled with dry mix compound and taped. If done properly, nothing wrong with it. In order to overlap the flange, wall studs would have to be furred out the thickness of the flange. I don't usually see it done that way on new houses, only on remodels.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
chrisBC (01-04-2012)
Old 01-01-2012, 04:42 PM   #8
Hi Mike,
What is the difference then in one properly done vs not properly done..
Is there something to look for?
This was a hybrid new construction/remodel as home was gutted due to natural disaster...
After it was mentioned, I did check the sterling install instructions and it calls for over the flange..
I've been trying to find something in the code that dictates, but have yet to find anything applicable....
Thanks..
Old 01-01-2012, 05:22 PM   #9
Originally Posted by steelgoddess View Post
Hi Mike,
Thanks..
Steelie,
As long as moisture resistant drywall was used along with the dry mix joint compound and tape, there shouldn't be an issue. The joint where the drywall meets the tub should be caulked. If somebody used premix joint compound like you see in the plastic tubs, you would probably know it by now. It isn't made to bridge big gaps and would shrink and crack and crumble in short order.
Mike Hawkins
Old 01-01-2012, 07:22 PM   #10
Thanks Mike,
The boards they used were blue and green..so should be moisture resistant..
Based on what I see and feel, no caulk was used around either...There is a slight mud bulge...
One gets daily use, one really hasn't been used..
Hopefully, it won't be another issue.... as there are so many already...
so I can go back to counting fasteners
Old 01-01-2012, 10:53 PM   #11
Registered User
Rewards Points: 5,482
"I've been trying to find something in the code that dictates, but have yet to find anything applicable...." -------- http://gypsum.org/pdf/GA-216-2010.html
http://publicecodes.citation.com/ico...002_par013.htm
http://publicecodes.citation.com/ico...002_par014.htm
http://publicecodes.citation.com/ico...002_par010.htm
Have any questions, just ask!
Gary
Old 01-02-2012, 10:27 AM   #12
Thank you Gary for the links..
I have been through those trying to apply the standard to the pics.
Am I understanding it correctly that every 16" if using screws or a nail/screw combo, there should be some type of fastener? On the gypsum site they had it for 12" but if I extrapolate to 16" my pics don't look anything like I would imagine they should. The gypsum pictures were nice and uniform and lots of fasteners.
The codes don't seem to address the space between the flange and board, and looking through other forums it seems to be a well debated topic--two schools of thought.
Not enough fasteners may also explain another phenomena of the job, it seems every place they trimmed, or brought a hammer to, saw the area between the wall and the ceiling start to separate, crease etc. Logically if the boards were loose, that may account for the shifting... I am just thinking aloud here...
Thanks again!
Old 01-04-2012, 11:27 AM   #13
Looks like there probably isn't enough screws in the wall and this skim didn't go on thick enough or at least feather out the existing screws better. Also doesn't look like there is enough screws in most of the pics. but hard to tell since i'm not there.
As for your kitchen ceiling looks like they just didn't feather out the butts very good on the skim. As Joe knows tapers only pass one coat with the boxes when it's getting a textured ceiling. You need to basically recoat the ceiling like it's never been done or had just tape and one coat on it.
LR
luckyrabbit is offline   Reply With Quote
Old 01-05-2012, 09:27 AM   #14
Steel Goddess--your first photo of the wall with the waves and bumps--what was the resolution. I have a hall that pretty much looks the same and have just recently had a "professional" skim coat and paint. The wall still looks like your photo. The paint is Sherwin Williams Duration matte finish and does have a slight sheen when looking at the wall on an angle. The wall was originally papered and the stripper indicated the walls were not sized. I think there were bits of paper and glue left and the first time the wall was painted after the stripping, all of the remaining residue was painted over. Since I was traveling for business when this was going on, I did not pay much attention but now I want that wall fixed. I suggested the the painter that maybe another round of skim coat would help. He said I was too much of a perfectionist and walked out! My husband wants to rip all of the drywall in the hall out which would also include removing all of the trip, door jambs, etc. (the baseboard was removed before the painting because we are upgrading it). The wall looks worse from the floor to about 4 feet up. Could a huge section of wallboard just be cut out and replaced or is there anyone else out there that could give me some advice? I spent $1200 on a 17 foot hall that doesn't look any better now than it did before. Thanks!
scamp01036 is offline   Reply With Quote
Old 02-18-2012, 12:26 AM   #15
Scamp, there has not been a resolution yet... we are heading into that.. see next post..
Floating, redoing, using a surfacer, really flat paint...all can come into play with walls like that...
What did you decide to do? Did it work, or are you still working with it?
Drywall ceiling above bathtub/shower larabiec Drywall & Plaster 3 06-26-2011 01:23 PM
Cutout in drywall around sink coutertop bananey Drywall & Plaster 4 05-04-2011 04:47 PM
Attach Drywall through plywood HooKooDooKu Drywall & Plaster 2 01-20-2010 10:05 PM
drywall seam issues onemeek Drywall & Plaster 16 04-06-2009 04:39 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
