Drywall Issue At Baseboard - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-05-2011, 09:34 PM   #1
Rewards Points: 337
Drywall issue at baseboard
Pulled the carpet out and baseboards to have tile installed. On one of my exterior walls I have noticed that from heavy rains a few yrs back I got some moisture from the soil on the outside being too close to the weep flashing. So I figured this might be an issue. We lowered the soil level a few years back has not been an issue. When I pulled the baseboards the area behind the baseboards is shot. Not wet but it's been wet at some point. There was some black mold on the baseplate and back of the baseboard too. The drywall just crumbled 2" up from the slab. So what do I need to do to fix this as tile installer is coming on monday.
I guess the tile can still go in since the they tile up to the drywall. Bummer.
titan7 is offline   Reply With Quote
Old 02-06-2011, 12:48 AM   #2
Pretty simple. I would measure up from the floor say 3in on both sides of your wall (each end) snap a line then cut that out with a knife. Then kills or a water bleach mix in a fertilizer sprayer and spray the wood and mold. (I have a extra fertilizer sprayer 5 gallon pump is why I choose this method). Then let it dry like an hour. cut some new strips of drywall your width of the gap you cut out and done.
Ohh I said 3in for the fact most base trim is 4in tall. So there is no finish drywall work if you don't want too.
proremodel is offline   Reply With Quote
Old 02-06-2011, 01:22 AM   #3
Rewards Points: 337
Thanks the problem is we have 2 1/2" baseboards. then I am also concerned there may be more (higher up the wall inside) than I can see. I really hate to cut out all that drywall and have to re-texture etc. but if I only cut out this small section it will only get worse.
Old 02-06-2011, 01:30 AM   #4
You can spend the 160 bucks on the new dewalt camera. That way you can look up the wall with it and see how far the mold goes. There is really not much you can do. Well saying that if you get camera and see it is just a few bays and only the bottom plate. You can still cut out the bottom drywall say only 2 in up. That way you put the new strip of drywall in and your trim covers it.
Drywall over Drywall.. NoviceHandyman Drywall & Plaster 6 01-10-2011 09:32 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Ecorock (new green drywall product) Sir MixAlot Drywall & Plaster 0 06-20-2009 09:40 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 01:28 PM
