Drywall Issue Above Shower Enclosure - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-18-2013, 06:06 PM   #1
Drywall issue above shower enclosure
We have a 32" square shower enclosure. The walls above the shower are sheet-rocked. There is some water damage where the shower wall meets the sheetrock. The damage is just the sheetrock paper coming off the sheetrock, but it is unsightly. Is there anyway to fix this without removing the shower enclosure and replacing the sheetrock?
dstorjoh is offline   Reply With Quote
Old 09-18-2013, 06:25 PM   #2
Rewards Points: 5,974
Cut the loose paper off seal the exposed drywall with Gardz and proceed with finishing as planned.
Old 09-18-2013, 06:29 PM   #3
Rewards Points: 13,712
Got a picture so we can see just how bad it is?
Old 09-18-2013, 09:12 PM   #4
A picture of the damage
Here is a picture of the worst spot. Mostly cosmetic. I would like it all white again. I live in SW Iowa, it is humid here.
Old 09-18-2013, 09:29 PM   #5
Can I cut the paper, skim coat with drywall mud and sand (to even out the surface), and then coat with Gardz? Then paint it white.
Old 09-19-2013, 05:55 AM   #6
Yes but you might want to Gardz also before you skim, it will seal the cut edge of the paper so it doesn't come loose again from the moisture in your mud.
Hardibacker Cement Board Thickness Issue With Drywall JasonCA Remodeling 4 02-24-2013 01:00 AM
Shower Pressure Issue Jefferx Plumbing 5 01-19-2013 09:35 PM
Shower tile on drywall pisbouts Tiling, ceramics, marble 2 11-18-2012 11:32 AM
What to put above shower enclosure JakAHearts Kitchen & Bath Remodeling 5 08-23-2010 10:17 PM
Shower has drywall (not green) can I install Cement board Right over it? jwhiteuwc Drywall & Plaster 14 02-03-2009 02:20 PM
