Drywall Instead Of Trim Around Window - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-31-2011, 05:26 PM   #1
Drywall instead of trim around window
I want to drywall around my window frame instead of using trim. There is a gap about 2 1/2 inch between the drywall on the wall and drywall in the window (see picture). There is also 3/4 inch between the wall and window. If I drywall this, will i have any problems such as cracking in the future? I want to use corner bead but there would still be a gap. Can anyone suggest how to fill in the gap?
Drywall instead of trim around window-img_6751.jpg   Drywall instead of trim around window-img_6756.jpg
MP_777 is offline   Reply With Quote
Old 01-31-2011, 06:22 PM   #2
Rewards Points: 16
A previous owner of my home did this with a door frame when they moved the door. The paint always cracks and inch from the edge. A fresh coat of paint will last maybe a year then it starts to crack all along that edge.
I think the walls are lighter and more flexible and they must move more than the heavily reinforced wood frames.
I think this is why these areas are always trimmed.
TechLauren is offline   Reply With Quote
Old 01-31-2011, 11:34 PM   #3
I do them all the time. They look awesome. What I would do in your case with that gap is put fiber tape to the corner covering the gap. 20 min mud the gap. Your going to have to fill that gap probably twice. Then once that dries about a hour total. Put on your corner bead (I love the metal with paper on them personally). Then mud the corner and smooth out about a foot from the edge to taper out the edge. Done. (tinted top coat mud is my choice for finish work)
proremodel is offline   Reply With Quote
Old 02-01-2011, 12:24 AM   #4
Registered User
Rewards Points: 526
Why was the plywood installed too far out, flush with the face of the drywall? If it was held back the drywall thickness, no problem... The f.g.insulation is barely better than nothing at all; http://books.google.com/books?id=a29...(1995)&f=false
The edge plywood will show through years later as it will move differently than a stud face, I'd use setting mud and paper tape to hide the inevitable crack.
Gary
Old 02-06-2011, 04:26 PM   #5
I would need to know if the plywood and the sheetrock planes out with the existing surface or is it back the thickness of the rock?
redmanblackdog is offline   Reply With Quote
Old 02-06-2011, 07:00 PM   #6
Phoenix
I might consider taking the window & the plywood out & reframing with 2 X 4 (or whatever size the wall is already framed with). After that i would consider cutting the drywall 6 inches larger than the existing opening (or at least to where new drywall can land on a stud on the left & right sides). I would then attach backer boards (maybe the old plywood?) to the existing drywall so new pieces of drywall can be installed between the window opening & the old drywall (that we just cut into). Then cut strips of nice new drywall to install between the backer baords & the nice new window framing, then your corner bead, then some mud & voila I can't say that i like the plywood being around the frame much personally.
Did you just install a new window? Was there cracking around the window frame drywall before? If so maybe it was caused by the plywood framing around the window?
Axecutioner-B is offline   Reply With Quote
Old 02-08-2011, 04:31 PM   #7
Thanks for all your inputs. The window was installed by a window installation company. I told them that we wanted to use drywall instead of trim. I didn't realize when they finish that the plywood being flush to the drywall would be a problem. My initial thought was to use the nylon tape and then corner bead but I was concern about the plywood. Since I have not started work on it, I will give the company a call and see they can come out to fix it.
Old 02-08-2011, 10:55 PM   #8
How bout this. Snap a chalk line 1/2in back on the ply and cut it out. Then you can run drywall flush with the wall and it will be alright for a good while.
Old 02-09-2011, 08:23 AM   #9
rditz's Avatar
what is the depth of the window sill, is there enough room to get a circular saw in there to cut the plywood back the 1/2" needed for the drywall to come and cover it?? it looks deep enough, you will have to finish where the saw won't reach with sawzall or by hand saw.
rod
rditz is offline   Reply With Quote
Old 02-09-2011, 09:00 AM   #10
Rewards Points: 151
If you're going to cut it, you 'could' try a multi tool with a plywood blade. It will take longer, but create less dust and help you get into tight places like the corners.
wease is offline   Reply With Quote
Old 02-09-2011, 09:14 AM   #11
rditz's Avatar
never used one... cool idea...
Old 02-09-2011, 09:22 AM   #12
Rewards Points: 151
My Dremel Multi is my favorite tool right now.
Old 02-09-2011, 09:26 AM   #13
rditz's Avatar
i know that to cut the window frame that 1/2" with a circular saw is messy and awkward (been there - done that)..
rod
Drywall around Window. RalphPeters Drywall & Plaster 1 05-23-2010 03:07 PM
After the Fact Exterior Window Trim? jonathan03 Remodeling 3 03-15-2010 04:36 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Stool and Apron Window Trim Style Advice DIYCarp Carpentry 8 01-24-2009 09:31 AM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-13-2005 11:59 PM
