Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-14-2013, 05:13 PM   #16
drywall and installer both cracked
thanks again everyone for the info and advice. I will give that a go ASAP and hope for the best...
rtoni is offline   Reply With Quote
Old 01-14-2013, 07:40 PM   #17
Moderator
"GBR - thanks for the links. Off topic - there's an interesting bit of info in the CUREE paper about orientation of drywall vs wall strength e.g. wall is 50% stronger when drywall is applied horizontally. I'm sure I've seen that topic debated a few times, if I recall."------------------------- I usually show this, first table; https://docs.google.com/viewer?a=v&q...U1o3kfoOlKl-7Q
And this, pp.12, and fig.9; "Results of tests for 24-foot walls, with and without
windbracing (fig. 9), showed a 50 percent increase in
ultimate strength for horizontal versus vertical panel
orientation. For the vertically oriented panels, nail loads
along the bottom edge caused the gypsum core to crack
and fall away from the panel." From; http://www.fpl.fs.fed.us/documnts/fplrp/fplrp439.pdf
Gary
PS. You're welcome, glad we could help.
Clothes taking longer to dry?
Gary in WA is online now   Reply With Quote
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 63 12-17-2012 10:29 PM
Drywall wavy/lumpy scamp01036 Drywall & Plaster 3 01-05-2012 12:14 PM
Drywall issue at baseboard titan7 Drywall & Plaster 3 02-06-2011 01:30 AM
burning in thinset on drywall rocketdoctor Building & Construction 1 01-08-2010 09:17 PM
P/T Lumber-Ground vs. Concrete WShawn Building & Construction 12 05-06-2008 09:45 PM
