Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall
Old 06-29-2009, 04:22 PM   #16
Hang,Finish,Texture,Paint
Sir MixAlot's Avatar
Drywall Installation-Finishing-Texturing tips
Originally Posted by HABSFAN2006 View Post
Question for ya... what is the advantage of placing mud in a straight line covering all screws in that specific grid, as opposed to two or three different patches of mud? I noticed some people do this..
is it to trick the eye and eliminate the "patch look" of different mud locations? Seems like more mud than is needed... Speed. It's one motion for multple fasteners. Instead of one motion for each fastener. Which turns into alot of time saved on large job.
also, is it better to have them vertical up/down on a wall application? I think vertical is more of a natural motion.
I have successfully done the patch methode before & primed/painted with good results... Both way's are fine.
Hope this helps.
www.PeckDrywall.com ------------My Blog
www.PeckPainting.com-------------Facebook
Sir MixAlot is offline   Reply With Quote
Old 06-29-2009, 04:35 PM   #17
HABSFAN2006's Avatar
Originally Posted by Sir MixAlot View Post
Hope this helps.
great, thanks! I can imagine you could save some time for sure.
Life is an experience... Learn from it!
HABSFAN2006 is offline   Reply With Quote
Old 06-30-2009, 11:00 AM   #18
Drywall contractor
Yep, say if you're using screws spaced every 8" or so it's much faster to "swipe" them vertically. If you're gluing and nailing with one set of nails in the field, it's easier to just spot the individual set than "swipe" across several studs horizontally.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is online now   Reply With Quote
Old 06-30-2009, 01:29 PM   #19
And saving time = $$$$$$$$$
Old 06-30-2009, 02:18 PM   #20
Although I am only a diy'er, I have worked on 4 basement projects and gaining much skill / experience with drywall and pulling joints, but I always like to work like the pro's work.. use the tools, materials, they use, and methods they use... I know the guys that did my home at construction did not use a corner trowel, and insisted on applying mud to one side at a time in corners to allow faster drying and finish the next day.
I am not a fan of corner trowels as they are not wide enough for finishing coats anyways.
Do you guys use them?
Old 07-03-2009, 06:58 PM   #21
I'm installing a large sheetrock ceiling and was wondering if I should cut Vs in the end of the sheetrock for butt joints before I apply mud and tape? Any words of wisdom?
gregezzell is offline   Reply With Quote
Old 07-05-2009, 06:56 PM   #22
No weld prep. required,
just butt up, and use as is. the proper amount of screws ensures no movement/no cracks.
Old 07-06-2009, 05:53 PM   #23
How flat is flat enough when it comes to residential drywall finishing? I know that is probably a bit of an ambiguous question dependent on level of finish texture etc.. But for example with a orange peel or knockdown texture is 1/8 of variation over 6 feet for example going to be noticeable to an average person, what about 4 or 2 feet?
riftsawn is offline   Reply With Quote
Old 07-06-2009, 06:41 PM   #24
It will not be visible to most... and surely should not be measured... some say use a 10" knife and no light should be seen at any point when slide across the joint. Then again, what might be acceptable for some, might not be for others.... I would say have at it, throw yourself into it, with small coats. It is better to apply 3, or 4, or 5 small coats, then one or two big coats. You can always add very easily..... It becomes a pain to remove,
have fun!
Old 07-08-2009, 02:11 AM   #25
A corner trowel can be tricky to use probably not recommended for a DIYER as it takes awhile to get he hang of them. however if they are mastered they can work very well and save time by coating both sides at the same time you can touch up both sides the next day if need be. you only really need to coat angles 4 to 5 inches wide when coating with hand type tools. these corner trowels can also create more work if you dont know what to look for when using them. a DIYER i recomend a 5 inch knife and do 1 side at a time..
oldrivers is offline   Reply With Quote
Old 07-08-2009, 02:24 AM   #26
i myself find that by the time drywall is delivered and hung it gets beat up alot espessially on the edges. i always take a knife and cut small vees on the ends" buttjoints" just to cut off any loose paper and then i prefill with setting muds prior to taping ,this repairs any damage that was casued by handling and it also makes the seems stronger in the end. not neccesarily needed but its a good insurance against blisters etc. alot of times stocking drywall in basements and other hard to access areas puts alot of damage on the rock because it gets draged scraped etc. a visual inspection should tell you if any extra measures need to be taken before taping.
Old 07-10-2009, 08:19 PM   #27
HABSFAN2006, I took some pics w/ my cell phone of the corner tool in action. I think the corners turn out much better with it than the mud one side at a time method.
Old 07-11-2009, 08:23 PM   #28
I am installing new drywall in a seasonal house. I am hoping to find a solution to the problem of drywall tape coming of the walls in a small house that is left unheated in upstate ny (lows of 20 below). is a setting compound the way to go, or mixing plaster of paris in with the joint compound?
garyweisman is offline   Reply With Quote
Old 07-12-2009, 10:37 PM   #29
Thanks for the pics, and I do hope there is enough mud under and over to permanently hold that paper in! But I generaly am not pressed for time, so I will ad a bit mroe than that, also, I would use a 5 or 6" nife, so not as long as that 10". What i meant was mostly finishing coats. Pros might get away with using on three coats... but my second and third coat always go pas the 3" of a corner trowel... on the upsides, I am content with my finished corners... it's a great tool though.
Old 07-12-2009, 11:15 PM   #30
Oh there is plenty of mud there to bed the tape. The pic was taken before the mud was ran out with the corner tool.
Let's see some of your pics.
More On This Topic
We finished our drywall. We put our first coat on yesterday, of drywall mud to seal up all the joints and the nail holes. This morning I came in and finished the top layer of the drywall. I used a twelve in knife which makes a nice wide band here, makes... Read More »
Alright, this is a really great example of a different kind of texture. We started with that really light texture that we had in the other room, but we added some more mud to this- some plaster on the wall with a trowel to get this look that we wanted... Read More »
How are you doing? My name is Noah Richardson from Elliot Construction. This is where the sheet rock joins together. It’s kind of like you’re sealing the deal with the rock right now. It’s only these spots that you use the tapes, like... Read More »
Installing new vinyl flooring is an inexpensive way to improve the look of a room, especially kitchens, bathrooms and laundry rooms. You can save quite a bit of money by installing the vinyl floor yourself. The most difficult step is applying the... Read More »
Hi I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. After your drywall has been taped and textured it's ready to cover up with paint, which is the next step. Painting is another job that a lot of homeowners... Read More »
Finishing drywall? gone_fishing Remodeling 9 05-14-2009 07:04 PM
finishing a drywall ceiling mmhendrie Building & Construction 12 03-17-2009 10:11 AM
Resilient Channels and finishing drywall Pat the Dad Building & Construction 5 06-08-2007 09:32 AM
tools for finishing drywall sedwick Building & Construction 8 04-21-2007 09:23 AM
drywall finishing BOP101 Building & Construction 3 10-07-2006 09:31 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
