Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-16-2009, 09:11 PM   #1
drywall installation on 9' wall
I am in the drywall stage of finishing my basement. The ceiling height is 9 feet . Using 4 x 8 sheets, does the 1 foot filler piece run along the center, or top of the wall? or doesn't it matter?
Thanks in advance.
SR996 is offline   Reply With Quote
Old 01-16-2009, 09:22 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
If using 48' sheets - Pro installation: Installed at center = for ease of coating. Requires advanced taping skills to incorporate seams smoothly to walls.
If using 48" sheets - Newbi installation: Install at ceiling height, or floor height. Make sure that all seams are factory to factory edge.
If using 54" sheets (Yes, they make them, drywall supply houses stock them) = One seam in the middle. 2 X 54" = 108" (9 FEET). Just make sure that you have an access route to bring them in, like a walk-out basement.
- Build Well -
Old 01-16-2009, 09:33 PM   #3
Thanks for the quick reply. My first thought was that having only factory edges meet would make finishing easier. However, this would mean a lot of waste. Guess I will have to hone my taping skills.
Old 01-16-2009, 10:55 PM   #4
+1 on those 54" boards
we just did a job and used 54"X120"X 5/8. Heavy ! ! ! but what a finish. Its one of the rare times where we told the homeowners feel free to use high gloss paint anywhere you want. The walls were close to perfect plus a good mud crew . . .
II Weeks is offline   Reply With Quote
Old 01-17-2009, 07:22 AM   #5
I was never a big fan of 1' fillers. Run a 2' piece at the top followed by a full piece, then a 3' piece at the bottom. This keeps the seams out of eye level and keeps the factory butt edges together. You'll get 2 two foot pieces out of one sheet and the only waste will be the one foot cut off the bottom sheet. Or, get 54"
jerryh3 is offline   Reply With Quote
Old 01-19-2009, 01:38 PM   #6
I agree with Jerry3h. 1' dw strips are not a good idea
mrgins is offline   Reply With Quote
Old 01-20-2009, 03:38 PM   #7
Drywall contractor
54" or 9' stand-ups. If you're using 8' board and laying it down, it's going to be a finishing nightmare....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 01-20-2009, 05:59 PM   #8
Lots of great advice about ways to install 9' drywall above. Let me throw in the option of just putting in 8' of drywall for easy finishing and a drop the ceiling to hide utilities and allow access.
Old 01-20-2009, 06:46 PM   #9
for get about the finishing aspect. you'll have to do that no matter what. now you need to consider the long term.
pros and cons
pros
9' ceiling has more appeal and will fetch you more for resale
great for home theater rooms
cons
cost more to heat and cool
Old 01-20-2009, 07:09 PM   #10
Yuck!
Seriously, you're kidding...right?
We've been ripping those out of ceilings for years, because just about everyone hates that look, and the loss of their ceiling height.
The only places we see that type of thing, are on ceilings in "triple deckers" (3 family homes), in the inner city .... and the apts are all rentals.
- Build Well -
Old 01-21-2009, 10:02 AM   #11
Drywall contractor
Not to mention the cost these days. Price the ceiling grid and some nice revealed edge tile and the cost can be staggering. Looks too commercial too.....
Old 01-22-2009, 08:39 PM   #12
Thanks for all the good advice. I went with the filler at the top, matching factory edges.
I never even considered a drop ceiling - personally, I just don't like the look, and the cost is outragous when compared to a few sheets of drywall , some tape and spackle. As my wife likes to say - my labor, after all, is FREE .
Sound dampening advice needed steel1 General Discussion 10 10-22-2008 02:51 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Drywall over existing wall? benbuchwalter Remodeling 3 02-21-2008 11:57 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
