Drywall Installation - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-24-2009, 11:56 AM   #1
drywall installation
I can't seem to find the answer to this but I am wondering why we install drywall perpendicular to studs/joist. Why do we not run them vertically on the wall and only have one bevelled seem vs. the butt joints that horizontal installation produces.
Thanks,
Mike
Mike L is offline   Reply With Quote
Old 08-24-2009, 12:51 PM   #2
Remodeler
adpanko's Avatar
Rewards Points: 150
benefits of horizontal over vertical (found this quote from some other forum a while ago):
1. Reduces the lineal footage of joints to be treated up to 25%.
2. Strongest dimension of board runs across framing members.
3. Bridges irregularities in alignment and spacing of frame members.
4. Better bracing strength—each board ties more frame members
together than does parallel application.
5. Horizontal joints on wall are at a convenient height for finishing.
For wall application, if ceiling height is 2460 mm (81) or less,
perpendicular application of standard 1220 mm (4) wide panels
results in fewer joints, easier handling and less cutting. If ceiling height
is greater than 2460 mm (81) or wall is 1220 mm (4 ft.) wide or less,
parallel application is more practical."
adpanko is offline   Reply With Quote
Old 08-24-2009, 11:31 PM   #3
Rewards Points: 256
lets say you have a 12 foot wall you would have 1 seem running east to west 12 ft , if you stood them up you would have 2 seems 8 f tx 2 ==16ft ,
plus when you stand them up, the seem has more of a tendency to catch light going accros it , you almost always have to run them wider anyways like a butt joint. and its easier on the back doing 4 butt joint versus 24 flatts bending over. basically its easier to finish and easier on your body.
oldrivers is offline   Reply With Quote
Old 08-29-2009, 09:19 AM   #4
Drywall contractor
Rewards Points: 1,070
All of the above is correct. These days even 9' walls can be "laid down" with the use of 54" wide drywall. (Available at a drywall supply.)
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Best way to repair poor drywall installation? RyanD Drywall & Plaster 5 05-19-2009 09:13 AM
Drywall installation Cossack Drywall & Plaster 3 02-15-2009 11:28 PM
New Drywall Installation, 1 joint screws are popping zjowens Drywall & Plaster 29 01-02-2009 01:26 AM
drywall installation peggyjayp Drywall & Plaster 4 08-13-2008 08:09 AM
3/8" Drywall Installation Question pjmachine Remodeling 10 02-27-2008 06:07 PM
