Drywall Installation - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-15-2009, 06:22 PM   #1
Rewards Points: 150
Drywall installation
We have taken the plaster off the ceiling and walls down to the studs. All insulation has been installed. Do I drywall the walls or ceiling first?
Thanks to all who answer.
Cossack is offline   Reply With Quote
Old 02-15-2009, 07:38 PM   #2
Remodeling Contractor
drywall the ceiling first
Old 02-15-2009, 11:17 PM   #3
Bob is correct, however when it comes time to do the walls, start your sheets at the top, not on or near the floor. It will save time and fustration trying to fit drywall between the sheets.
Mop in Hand is offline   Reply With Quote
Old 02-15-2009, 11:28 PM   #4
Install the drywall on the ceiling first. Then install the top sheet on the walls. This method will allow the top sheets on the wall to help support the edges of the ceiling sheets as well.
jonblack
jonblack is offline   Reply With Quote
drywall installation on 9' wall SR996 Drywall & Plaster 11 01-22-2009 08:39 PM
Drywall installation...longer better? gone_fishing Drywall & Plaster 9 01-10-2009 03:46 PM
New Drywall Installation, 1 joint screws are popping zjowens Drywall & Plaster 29 01-02-2009 01:26 AM
drywall installation peggyjayp Drywall & Plaster 4 08-13-2008 08:09 AM
3/8" Drywall Installation Question pjmachine Remodeling 10 02-27-2008 06:07 PM
