Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-29-2011, 06:22 PM   #1
Drywall installation
I am installing Humitek sheetrock in basement againsst outside walls, please tell if the blue or white side is applied towards the concrete wall Ron E
ron e is offline   Reply With Quote
Old 05-29-2011, 10:05 PM   #2
Old School
Willie T's Avatar
Look at the TAPER on the edges. That side goes outward (away from the wall) When it is hung, you will be looking at the tapered edges on your side of the work.
Personally, I would use Fiberock instead.
Willie T
drywall over old plaster... lcann25 Remodeling 0 09-21-2010 12:53 AM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 06:49 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
New Drywall Installation, 1 joint screws are popping zjowens Drywall & Plaster 29 01-02-2009 01:26 AM
