Drywall Install For Soffits - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-15-2012, 09:42 AM   #1
Rewards Points: 81
Drywall Install for Soffits
Hi,
For outside and inside corners on a soffit, I should cut the drywall so there is no tapered edge correct?
LarryM is offline   Reply With Quote
Old 08-15-2012, 10:18 AM   #2
Rewards Points: 13,740
Always best to have that edge tapered.
Outside edges will need an outside corner strip added and inside corners need to be taped. Without a taper your going to end up with bulges on the wall.
Old 08-15-2012, 08:37 PM   #3
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 908
Originally Posted by LarryM View Post
Hi,
Either way is fine. As long as both of the pieces are the same.
Sir MixAlot is offline   Reply With Quote
Old 08-15-2012, 08:42 PM   #4
DIY staff
Rewards Points: 7,174
I avoid tapers on the outside corners---leads to a straighter sdge
Old 08-29-2012, 03:46 PM   #5
Drywall contractor
Rewards Points: 1,070
Agree, no taper on the corner bead side. I really prefer not to have them on inside corners either where possible. There shouldn't be any "bulges" on the wall without a tapered edge. You don't need to pile a bunch of mud on the tape! All you're trying to do is "kill" the edge so it doesn't show, and leave enough on the tape to keep from "burring" it when you sand. The mistake people make is when they see some tape showing through the mud after they sand, SO WHAT?? The tape will paint! As long as there's no "defined" edge(s) paint will cover it. If there are issues where you see a problem after the prime coat, touch up with a light skim of mud. A tapered edge will often show worse because the average person doing an angle (with a taper) figures since the tape isn't showing it's done. Often due to corners not being exactly square, inexperience, etc. those angles will show after paint due to lack of enough mud.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Cement board over drywall during vinyl shower pan install asc12 Tiling, ceramics, marble 6 02-25-2012 07:19 AM
install ceiling box for fan while drywall is off collegetry Electrical 30 02-12-2012 09:17 AM
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 09:32 PM
Can I install mesh back mosaic tile directly to primed drywall jenrao9991 Tiling, ceramics, marble 5 03-17-2009 06:08 PM
