Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-23-2009, 07:45 PM   #1
drywall install on ceiling
I Am Making A Room 12x24 After I Put Walls Up Will 2x6 Be Heavy Enough The 12ft Length Every 2 Ft Oc To Hold Up 1/2 Drywall For The Ceiling?? I Am Thinking 2x4 Would Be Too Small Or Do You Need To Double Up On The 2x6 Like A Header??
buckbob is offline   Reply With Quote
Old 01-23-2009, 07:59 PM   #2
it would hold it up but you wont like the finish. Try to go every 16"OC and by the way, will this ceiling be holding anything on the side? Roof? Attic? Another floor?
If yes to any of these, your going to want to go bigger and definitely every 16.
II Weeks is offline   Reply With Quote
Old 01-23-2009, 08:10 PM   #3
What It Is A Pole Barn I Am Going To Nothing Fancy Finish Of An Area 12x24, Nothing Over The Ceiling (drywall) Just Some Blown In Insulation And Then Just Texture The Drywall With Some White Paint Mixed In A Few Buckets Of Drywall Mud So You Think 2x6 S Will Be Fine Every 16 Inch Oc??
Old 01-23-2009, 08:19 PM   #4
the Musigician
DangerMouse's Avatar
1/2" on 24 will likely sag unless you buy specific 1/2" ceiling drywall or use 5/8"
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 01-23-2009, 08:28 PM   #5
Do You Think 16 Oc Would Solve The Sag, I Had No Idea There Was Such A Thing As Ceiling Drywall
Old 01-24-2009, 07:26 AM   #6
the Musigician
i never did either until recently....1/2" ceiling drywall is 'stiffer' to avoid sags, but not as available i've noticed.
i ended up with 5/8" at 24OC in our dining room addition, but my homemade drywall lift made it easy to install the heavier panels.
if you mud/painted and it sagged, i'd hate to have to clean up the mess.
DM
Old 01-24-2009, 07:38 AM   #7
C'mon DM don't be modest show him your plans
Chemist1961 is offline   Reply With Quote
Old 01-25-2009, 01:35 PM   #8
Pictures of your drywall lift pleeeeeese!!!
Timberwright is offline   Reply With Quote
Old 01-25-2009, 01:44 PM   #9
the Musigician
http://www.diychatroom.com/f29/free-...ll-lift-33625/
DM
Old 01-25-2009, 07:27 PM   #10
Professional Wood Shafter
ryanh's Avatar
If you are worried about sagging definally use ceiling dryway, if your 16 o/c then normal drywall shouldn't sag if screwed off properly
ryanh is offline   Reply With Quote
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 10:50 AM
Shower has drywall (not green) can I install Cement board Right over it? jwhiteuwc Drywall & Plaster 14 02-03-2009 03:20 PM
Drywall over existing ceiling? billybarty Carpentry 1 03-08-2008 12:05 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
