Drywall Install - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-26-2011, 08:46 AM   #1
drywall install
i have 9' basement walls and will be putting a drop ceiling in at 8', do i put the filler at the top were it will be hidden or do i start at the top and go down? my contractor that built the house went top to bottom in the bathroom but that has a finished drywall ceiling.
jnkremer83 is offline   Reply With Quote
Old 11-26-2011, 08:50 AM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
If your ceiling height is 8', you shouldn't need a filler.
tcleve4911 is offline   Reply With Quote
Old 11-26-2011, 08:58 AM   #3
Rewards Points: 582
agree why do you need a filler at 8'.....and if you think about it stand board up .bring drop ceiling channel one inch below top of board ..good to go ..yes finish height 7' 11"
Old 11-26-2011, 11:50 AM   #4
Rewards Points: 89
Space above the drop cieling may have to be draftstopped depending on the type of joist construction
spring3100 is offline   Reply With Quote
drywall over old plaster... lcann25 Remodeling 0 09-21-2010 12:53 AM
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 04:13 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Can I install mesh back mosaic tile directly to primed drywall jenrao9991 Tiling, ceramics, marble 5 03-17-2009 07:08 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
