Drywall Inside Utility Alcove, Yay Or Nay - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-27-2011, 12:19 AM   #1
Rewards Points: 1,062
Question
drywall inside utility alcove, yay or nay
any reason why i should hang DW inside my utility (water heater and hydronic radiator boiler, both gas)? i was planning to just leave exposed 2x4 and, of course, have DW on the outside.
Old 05-27-2011, 10:40 AM   #2
Drywall contractor
Rewards Points: 1,070
I've seen it done both ways. No reason to unless it's a code issue. Check with the local building dept.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
how to side the top of an alcove ?? papageek Building & Construction 6 12-15-2010 07:53 AM
Mating drywall to plaster on an inside corner acme54321 Drywall & Plaster 4 10-14-2010 12:09 AM
drywall over old plaster... lcann25 Remodeling 0 09-21-2010 12:53 AM
My window between siding and drywall... jamieofansa Drywall & Plaster 2 09-05-2010 09:55 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
