05-27-2011, 12:17 AM
#1
drywall inside shed, yay or nay
any reason why i should post drywall inside my 11x9 shed? i was planning to just leave exposed studs and OSB sheathing
05-27-2011, 10:42 AM
#2
Drywall contractor
Either way is ok. If you want to cover the walls inside, I'd recommend plywood of some sort rather than drywall. Makes for a sturdier job and you can hang all sorts of stuff on plywood easier than drywall....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
05-27-2011, 12:11 PM
#3
Yes, I agree. Plywood would be better. Especially if you live in a damp area.
05-27-2011, 12:38 PM
#4
Drywall contractor
Yep, drywall is meant for a conditioned area without moisture or humidity.....
05-27-2011, 09:16 PM
#5
no its a shed .sometimes that extra few inches can come in handy small shelves in between studs place to hang tools .you will fill a 9x11 shed in no time every inch counts
05-28-2011, 12:55 AM
#6
You sound like my parents. I hate that thinking, you can NEVER find anything because every square inch gets filled with crap! I like things best clean and organized and if it don't fit, you'll probably never need it anyways.
05-28-2011, 05:43 PM
#7
yeah i'd use plywood, or that pegboard stuff you can hang all kinds of shelves and hooks from.
06-04-2011, 12:10 PM
#8
In a little over my head
IMO, drywall in a shed is a waste of space. Do part of it with shelves between the studs, part with pegboard. Leave most alone, until you figure out what goes where.
06-04-2011, 02:20 PM
#9
I cover the walls of sheds/workshops/garages with the 1/4" thick 4x8 sheets of pegboard. Makes for lots of storage options and looks nice (for a shed / workshop). You can get it already painted white - so no painting needed (I hate painting...). Quick and easy to put up. Screw it to the studs with drywall screws, rather than nail - makes it easy to remove as may be needed to add electric or something else.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
