-   -   drywall inside shed, yay or nay (http://www.diychatroom.com/f101/drywall-inside-shed-yay-nay-105727/)
amakarevic 05-26-2011 11:17 PM
any reason why i should post drywall inside my 11x9 shed? i was planning to just leave exposed studs and OSB sheathing
bjbatlanta 05-27-2011 09:42 AM
Either way is ok. If you want to cover the walls inside, I'd recommend plywood of some sort rather than drywall. Makes for a sturdier job and you can hang all sorts of stuff on plywood easier than drywall....
dberladyn 05-27-2011 11:11 AM
Yes, I agree. Plywood would be better. Especially if you live in a damp area.
bjbatlanta 05-27-2011 11:38 AM
Yep, drywall is meant for a conditioned area without moisture or humidity.....
ltd 05-27-2011 08:16 PM
no its a shed .sometimes that extra few inches can come in handy small shelves in between studs place to hang tools .you will fill a 9x11 shed in no time every inch counts:yes:
dberladyn 05-27-2011 11:55 PM
You sound like my parents. I hate that thinking, you can NEVER find anything because every square inch gets filled with crap! I like things best clean and organized and if it don't fit, you'll probably never need it anyways. :)
chrisBC 05-28-2011 04:43 PM
yeah i'd use plywood, or that pegboard stuff you can hang all kinds of shelves and hooks from.
ratherbefishing 06-04-2011 11:10 AM
IMO, drywall in a shed is a waste of space. Do part of it with shelves between the studs, part with pegboard. Leave most alone, until you figure out what goes where.
vsheetz 06-04-2011 01:20 PM
1 Attachment(s)
I cover the walls of sheds/workshops/garages with the 1/4" thick 4x8 sheets of pegboard. Makes for lots of storage options and looks nice (for a shed / workshop). You can get it already painted white - so no painting needed (I hate painting...). Quick and easy to put up. Screw it to the studs with drywall screws, rather than nail - makes it easy to remove as may be needed to add electric or something else.
