-   -   Drywall Hung In Wrong Direction On Ceiling (http://www.diychatroom.com/f101/drywall-hung-wrong-direction-ceiling-160918/)
RandyJames 10-23-2012 11:43 AM
Started hanging 5/8" drywall on the ceiling of my garage. I'm using 4 x 8 sheets and rafters are on 24" centers. After getting 4 sheets up I found out I should have been installing the sheets perpendicular to the rafters instead of parallel to them. Would the experts advise I take these down and rotate them to the correct direction to prevent sagging or are there other options?
notmrjohn 10-23-2012 12:47 PM
Since its only four sheets, best take um down and start over. Dry wall is stronger in that direction, less sag. The butt joints will be easier to tape out evenly.
scottktmrider 10-23-2012 03:54 PM
I would leave it since its 5/8 and only 8' long it wont sag, and its just a garage.Unless you didnt add more wood on the butt joints.
RandyJames 10-23-2012 06:08 PM
Looks like I'll be pulling those 4 sheets back down. I had spaced my screws about 6" apart on the long edges of each sheet, so would there be any concern about all those holes weakening the sheet when I turn it and put it back up perpendicular to the rafters?
scottktmrider 10-23-2012 06:14 PM
Dont go in the same holes.Other than that you will be fine.At least you learned something mabye the hard way.
notmrjohn 10-24-2012 09:04 AM
Most of your new holes are going to be in lines perpendicular to those old ones. The old holes may give the mud something to grab into. Could be your mistake improved on traditional tape joint.:wink:
At least you caught yourself B4 you went to far and you didn't it wrong side out. I know a guy did that in a 16 X 24 addition I built for him. He said he thought the beveled edges had something to do with fitting over studs.
From that job I learned, when owner is going to do part of job, to first make sure owner knows how.
RandyJames 10-24-2012 11:17 AM
Thanks for the replies. Your advice is very much appreciated. And it was good to be reminded that it could always have been worse.
