Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 06-23-2008, 09:57 AM   #1
Drywall - hole for outlet bigger than faceplate
I'm in the process of hanging drywall in my basement and am cutting out the holes for switches and outlets by measuring from sides/top/bottom. Accidently, I cut one hole about an inch lower than it should be and so I had to cut another inch on the top to make it fit. Now the problem is that when I eventually finish and put a faceplate on it, a portion of the hole will show out.
What's the best way to cover that. If it helps, I still have access to the drywall sheet from the back as well (from framing side, that is).
Suggestions please.
Thanks!
slinku2020 is offline   Reply With Quote
Old 06-23-2008, 10:20 AM   #2
scrap piece of drywall or small piece of plywood BEHIND the area(can be glued and or screwed),,a small piece of drywall glued to that backerboard,,,tape and finish over THAT!!
4just1don is offline   Reply With Quote
Old 06-23-2008, 10:31 AM   #3
RippySkippy's Avatar
That will work great. In addition, when you're mudding, go around each box and fill in the gap between the box and the drywall...it'll take care of any oversized/overcut holes and make for a neater more professional look. Lightly sand before texturing or priming and you'll be good to go.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 06-23-2008, 05:36 PM   #4
You can try these outlet patches:
http://www.all-wall.com/acatalog/Str...ex.php#aSFOP20
jerryh3 is offline   Reply With Quote
Old 06-24-2008, 10:31 PM   #5
Drywall and Painting Pro
Sir MixAlot's Avatar
Yep!!
Checkout some of
Sir MixAlot is offline   Reply With Quote
Old 06-26-2008, 12:38 PM   #6
Thank you all for the responses. I think I will try sticking a piece of wood behind it and glue a piece of drywall to cover up my mistake.
Thanks again.
Old 06-30-2008, 02:10 PM   #7
You can also purchase over sized wall plates as well.
-JS
devouru is offline   Reply With Quote
Proper way to repair oversized outlet hole in drywall Plasmech Painting 16 06-24-2010 12:09 PM
drywall ceiling hole repair billyg Drywall & Plaster 5 06-10-2008 05:19 PM
Help - Patching a Hole in a Drywall Ceiling ... njchan Building & Construction 9 04-10-2008 08:56 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
hole in drywall? econdave General Discussion 11 11-01-2007 06:29 PM
