Drywall Help Please!! - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-08-2011, 09:16 AM   #1
Drywall help please!!
I was fixing bubbles in a section of my wall and in some areas I am to the brown "paper" part of drywall. Is there something I can do to fix it? (I don't know if it matters, but on the other side of the wall is a toilet.)
I appreciate any help!
juevi76 is offline   Reply With Quote
Old 01-08-2011, 12:25 PM   #2
Definitely get rid of all loose material. The brown paper will work just fine as long as you haven't torn so much away that its almost impossible to get all of the loose stuff. But if it seems sound I wound just go over it with more mud. Of course if you are down to the the white core (gypsum) then you need to paper tape over that, with loose tapping mud. All purpose will work but it doesn't have as much staying power.
redmanblackdog is offline   Reply With Quote
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
